Milky oil - Ducati.ms - The Ultimate Ducati Forum
Old Dec 19th, 2011, 12:14 am   #1 (permalink)
Milky oil
Ok, so looked into the oil level glass this am and horror of horrors.....it was all White!
Now I know this means water in the oil.....but where is it coming from?
Bike is running fine, no noticeable water loss at the radiator end?
Could it be condensation.... It's been hovering around the 0deg Mark(35 F)?
How much water is needed to make the oil go milky....
will it go away or should I change the oil? Filter?
Or is it a workshop job?
multi rider is offline   Reply With Quote
Old Dec 19th, 2011, 12:28 am   #2 (permalink)
Mr Sunshine's Avatar
Unless its filled with water just ride and don't worry
You oil isn't sealed so water can absorb in. Getting it all the way to temp for a bit will help burn it off
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Dec 19th, 2011, 5:47 am   #3 (permalink)
Thanks Chris. After riding the bike yesterday I left the oil filler cap off overnite. This morning it looked like oil again, so assume the water evaporated away.
I hope its just condensation and not a leak in the water system, or worse a blown cylinder headgasket?
Old Dec 19th, 2011, 6:11 am   #4 (permalink)
It will be condesation, have you been doing short journeys
Mr C is offline   Reply With Quote
Old Dec 19th, 2011, 9:54 am   #5 (permalink)
mmm yes actually I have.
I have an 8 mile journey home tonight, will leave the oil cap off tonight again.
If it doesnt go away then I think I will drain the oil on the weekend.
Old Dec 19th, 2011, 9:58 am   #6 (permalink)
You need to give it a right good run
Old Dec 19th, 2011, 3:44 pm   #7 (permalink)
Relax I'm sure it's just condensation in the sight glass
Aztec is offline   Reply With Quote
Old Dec 19th, 2011, 10:14 pm   #8 (permalink)
Every Duc I've owned does this in the fall/winter. I reckon it's just a small bit of moisture on the inside of the glass because every time I have dropped the oil for this problem it has shown no signs of water contamination.
A couple of tricks:
(1) Cover 3/4 of the oil cooler.
(2) Take it for a good long ride.
(3) When you get home, lean the bike to the RIGHT so the hot oil covers the sight glass.
It might take a couple of tries, but this method has always worked for me.
ps The problem WILL return!
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
"milky" anodizing and etched exhaust Chilton Superbikes 8 Apr 26th, 2007 10:18 am
