Base/ base abs ohlins up grade "rear" - Ducati.ms - The Ultimate Ducati Forum
Old Dec 17th, 2011, 8:01 am   #1 (permalink)
Any one with a base or abs base want to up grade to a ttx ohlins rear shock let me know i have one that will bolt right on the stock location. It is a much better performing shock than the stock one.
ebrew is offline   Reply With Quote
Old Dec 18th, 2011, 12:07 am   #2 (permalink)
nice .....do you have any pics of it
enforcer is online now   Reply With Quote
Old Dec 18th, 2011, 7:01 am   #3 (permalink)
sure
Ohlins does not make this shock for our bikes. You have to get a shock from an s bike and convert it to a maunal set up. This bolts right on to the stock location of the sachs shock.
Base/ base abs ohlins up grade "rear"-1.jpg   Base/ base abs ohlins up grade "rear"-2.jpg   Base/ base abs ohlins up grade "rear"-3.jpg
Old Dec 18th, 2011, 5:29 pm   #4 (permalink)
thanks for the pic mate . i have PM on its way
Old Dec 18th, 2011, 7:58 pm   #5 (permalink)
Kitesurfer's Avatar
Sounds expensive: probably cheaper to buy an S
2010 Multistrada 1200SS White
2009 Suzuki GSX-R750 Black
Kitesurfer is offline   Reply With Quote
Old Dec 18th, 2011, 8:57 pm   #6 (permalink)
Not really
same as a ttx for a 1098/1198 from ohlins. When i did my conversion for my base abs there were no used MTS 1200s bikes out there that could be had so it was a full pop deal. I set up my bike front and rear and still was 3000+ in my pocket. I still do not want the push button suspension on a bike.I like a clicker and a screw driver to set it up. No DES errors or wondering if the preload is making a strange noise Blah blah. Im sure its good stuff just not for me. I wish it had a normal key and head lock but what can you do. Just love the bike.
Old Dec 18th, 2011, 9:10 pm   #7 (permalink)
Kitesurfer's Avatar
same as a ttx for a 1098/1198 from ohlins...
Sorry; I must have misunderstood the previous post that stated you needed a shock from an S bike (I presumed with the electronic actuators etc.)
Old Dec 18th, 2011, 9:27 pm   #8 (permalink)
Sorry yes you do need one from an S
If you can find one you can convert it. I just lucked out and found one at a good price and thought someone in my boat with a base would like it without having to go thru the brain damage i went thru doing the research. Have all the servos pulled and the new valves and preload put in. The problem is the head it is only made for ducati and you cant buy it. Other than that it is a ttx shock with valving and length for our bike and an external preload. They "ohlins" will not be making them anytime soon and i tried and tried. Ducati wants you to buy the more $$$ bike. I do understand their position. I could go on and on about this but its not very exciting.
Old Dec 18th, 2011, 10:28 pm   #9 (permalink)
djz
this is a simple way to upgrade to great shock
I think this is a great way to upgrade your rear end
Yes Wilbers makes shocks for your Multi. Wilbers are built to your weight and riding style. They are very high quality, fully rebuildable and have a five year warranty.
Here are the shock options for your model:
Model 640 with rebound damping and hydraulic preload adjust: $798.00
Excellent street bike shock for occasional off-road riding, best seller.
Model 641 with remote reservoir, remote hydraulic preload adjust and three way damping: $1098.00 Wilbers best shock for more off road riding and maximum street performance.
Our weekly order go to Germany every Saturday and arrive in about 3 weeks.
Thanks for the inquiry, feel free to call for a more in depth discussion about your suspension options.
Best regards,
djz is offline   Reply With Quote
Old Dec 18th, 2011, 10:36 pm   #10 (permalink)
ok
Thanx for the sales pitch. Is there a vendors section here. Would you like to talk about penske as well as they make nice stuff. Bi tubo , WP,should I go on?
New MTS 1200 "base" project ebrew Multistrada 10 Jun 2nd, 2011 11:51 pm
Base or "S"? mad StreetFighter 42 Dec 23rd, 2008 7:32 pm
Anyone with a "Base" HM change rear shock yet? josephvman HyperMotard 0 Apr 2nd, 2008 9:32 am
05 999 (base model) and "race" exhaust DMCTRUBY Superbikes 10 Aug 16th, 2007 11:44 am
