AFR and catalysts - Ducati.ms - The Ultimate Ducati Forum
Old Dec 10th, 2011, 2:14 pm   #1 (permalink)
AFR and catalysts
What about the catalysts and AFR? Catalysts are assumed to require an AFR of 14.7, but with fatducs, remapping of the ECU and the like to use a less than 14.7 AFR going to unburned fuel reaching the catalyst. Those who have installed some of these devices on a bike with the original muffler, have noted higher temperatures or other symptoms?
DiasDePlaya is offline   Reply With Quote
Old Dec 10th, 2011, 3:31 pm   #2 (permalink)
I was a bit concerned about the effect on the cat at first (with fatducs), but I've had them on thru two very hot summers now, and no problems with high temps. I just came in from an hour ride, about 50deg F outside, and the highest temp on the dash was 158F.
mollycbr123 is offline   Reply With Quote
Old Dec 10th, 2011, 7:09 pm   #3 (permalink)
Turkishexpress's Avatar
running richer = less heat
2011 Multistrada S - Street
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old Dec 10th, 2011, 9:42 pm   #4 (permalink)
I'm asking about heat in the catalyst, not the engine.
Old Dec 10th, 2011, 11:22 pm   #5 (permalink)
Mr Sunshine's Avatar
Don't worry about it. You aren't going to make so rich that it'll nuke the cat.
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Dec 11th, 2011, 12:35 pm   #6 (permalink)
I didn't think so, but my bike was one of those that had the burnt smell after a ride. It turned out to be the melting plastic cover on the exhaust flapper cable (remember that discussion?). I put the fatducs on very early on, so the thought that the smell might have been from them burning up the cat did cross my mind.
Old Dec 11th, 2011, 1:06 pm   #7 (permalink)
less heat from the engine = less heat to the pipes = less heat at the catalytic converter
Unless you run leaded fuel your cat is going to be just fine. Rest easy.
Old Dec 11th, 2011, 6:28 pm   #8 (permalink)
Yup I remember. . It'll also smell from the grunge you'll get from the road due to the heat.
:: Chris Burgess ::
#104
WMRRA
OMRRA
WERA
Old Dec 11th, 2011, 10:26 pm   #9 (permalink)
True. The last few weeks the bike has smelled like burnt leaves when I roll it into the garage. I got a lot of leaves on the driveway to rake up.
Old Dec 12th, 2011, 12:10 am   #10 (permalink)
+1... Smells like a hot Sydney summer if it's a dry day. MMmmm Warm Eucalypt smell !!
unreliable heap of shit (red)
DP Top box + HFF + Alarm
11-Aug-2010
(http://www.madcogz.com/ms-data.htm)
MODIFICATIONS
DP CF tail tidy - (www.proitalia.com)
RadGuards - (radiator + oil cooler) (www.radguard.com.au)
SW Motech header guard - (www.motorradgarage.com.au)
SW Motech crash bars - (www.motorradgarage.com.au)
SW Motech Hawk radiator light mounts - (removed due to recall)
SW Motech Hawk fairing mounts - (installed after all ... looks OK)
sheepskin seatcover - (www.goodwool.com
Givi touring screen - (ebay)
mivv decat and suono slipon (http://www.pjsparts.com/)
Denali D2's - ( www.twistedthrottle.com )
SupaBrake brake flasher. ( www.vizi-tec.com )
FatDucs O2 manipulators. (removed www.performanceboulevard.com)
Touratech Handguards
powdercoated bellypans and exhaust guard
CP-Wings
Headlight protectors
WARRANTY ISSUES(wrnty) DES rear shock Replaced. (mar 2011)
(wrnty) clutch mc replaced (mar 2011)
(wrnty) 2011 recall updates, fuelling ABS and Dash (may 2011)
(wrnty) DES Rear Shock ECU replaced (jul 2011)
(wrnty) 2011 recall updates, Handsfree, switches (jul 2011)
(wrnty) pourus Cylinder Head replaced (5-12-2011 to 19-1-12)
(wrnty) sudden coolant leak at 26700+km (May 2012)
REPAIRS
(idiot) jammed gearshift. fixed now. thankyou QBE.
WEAR and TEAR(wear) Chain/Sprockets toast & rear disk at min thickness at 26,700km
REASON in SHOP today ?Unbelivably FRASERS have been unable to source a new chain for 8 days now (and counting).
651 days old and 26,700+ km travelled as at 22nd May 2012
wcieslik is offline   Reply With Quote
