Multi S rear Ohlins Shock - Ducati.ms - The Ultimate Ducati Forum
Old Dec 10th, 2011, 7:16 am   #1 (permalink)
Folks, was wondering....
I had my bike on the centre stand this morning.... set the mode from urban to sport and nothing happened....
I thought that it should adjust the spring immediately....
Could it be that my Ohlin shock is f...ed?
Have checked all fuses....
How do you know if your shock is working correctly? I have no error messages.
Shock electrics were replaced in September.
multi rider is offline   Reply With Quote
Old Dec 10th, 2011, 9:13 am   #2 (permalink)
You should hear a buzzing sound of the suspension servos adjusting the forks and shock. The ride should change from Cadillac in urban to Ford pickup in sport. The height of the seat will also increase, very noticeable to me since im short.
2010 Multistrada 1200S Touring (Black)
bull rrider is online now   Reply With Quote
Old Dec 10th, 2011, 11:10 am   #3 (permalink)
not that familar with the suspension so excuse my ignorance. I thought sport set the power output and you're saying it changes the shock also?
number2 is offline   Reply With Quote
Old Dec 10th, 2011, 11:43 am   #4 (permalink)
Your are correct sport does change power output to an "150HI" hp compared to urban's 100 hp, but yes it does also changes the suspesion.
Here's a break down:
Sport ABS on DTC 3 150HI hp Seat height MED
Touring ABS on DTC 5 150LO hp Seat height MED
Urban ABS on DTC 7 100hp Seat height LOW
Enduro ABS off DTC 2 100hp Seat height HI
All models have the 3 engine maps and DTC. The "S" models get Ohlins DES (Ducati Electronic Suspension) with appropriate front/rear compression & rebound as well as rear preload suspension adjustments.
All features can be further tweaked to match your individual preferences. The bike will remember your settings. The exception is ABS which will always have to be manually turned off in the Sport, Touring, and Urban modes (the ABS remains on to some extent in all modes - it has to be separately shut off every time the ignition is turned off and back on).
In the default settings, when choosing enduro mode, the ABS is not active, however it is not completely disabled (I'm not aware of any varying levels of ABS), so if you switch from enduro mode to any of the other three modes, ABS will be active again.
On both the front and rear suspension, hydraulic compression and rebound damping is adjusted by electric actuators (with 31 progressive settings). Spring preload in both stanchions of the front fork is adjusted conventionally, whereas spring preload for the rear shock absorber is adjusted by an electric actuator (the rear shock absorber may be compressed by up to 8 mm, with sixteen different positions settable for the electric actuator. meaning that each subsequent position corresponds to half a millimetre of spring compression). Changes to the hydraulic damping settings are not accompanied by audible clicks. Therefore, to ascertain whether the dampers are working correctly, set to one extreme of their travel first and then to the other, comparing the different damping actions achieved by compressing and releasing the front and rear suspension repeatedly
Old Dec 10th, 2011, 5:03 pm   #5 (permalink)
dansz24's Avatar
I thought I had this problem too but realized that when you’re in any mode besides single rider and no luggage the shock preload is all the way up.
2010 MTS1200s touring
2009 MTS1100s
dansz24 is online now   Reply With Quote
Old Dec 10th, 2011, 6:01 pm   #6 (permalink)
Exactly!!!
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Dec 10th, 2011, 6:40 pm   #7 (permalink)
I forgot who originally posted this, but it's a thorough spread sheet of all of the default settings.
File Type: pdf MTS1200_DES_Suspension_Settings_mkII.pdf (72.6 KB, 52 views)
rob b
___________
'10 MTS 1200 S Sport/Touring
'06 ST3S (sold)
'08 S4RS #199 (sold)
'08 Husqvarna TE610
robb is offline   Reply With Quote
Old Dec 11th, 2011, 9:53 am   #8 (permalink)
Big Thanks
Thanks folks....
I suppose one should read the manual....
I did exactly as you said... went back and set the mode to single rider only and then changed from Sport to enduro, and guess what????
The servo immediately changes the compression of the spring! yihaa i am very happy now as we dont have to go to the dealer anymore....
you see I am a bit of a "fat ba...rd" at 115kg (approx 240lbs) so always ride with the settings at rider with lugage.
I wonder if I should consider an uprated spring???
Anyway thanks again for your input....good to know there are clever people on this forum)
Old Dec 11th, 2011, 12:11 pm   #9 (permalink)
Mr Sunshine's Avatar
I'm lighter than you and I want a heavier spring...I just haven't pulled the trigger yet.
So yes you should consider it. It'll make the bike more plush while handling better. If you have to add too much preload and compression the bike ends up getting a little ridged.
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Dec 11th, 2011, 6:51 pm   #10 (permalink)
I upgraded to the Ohlins 100 N/mm spring and could not be happier. I weigh ~240 lbs. in summer textile/mesh gear, ~250 lbs. in full leathers. The result was no more wallowing like a warthog in Urban mode, and it now rides on rails in the corners in Sport mode. A word of warning, though - when you stiffen the rear spring, be prepared to realize that the front fork springs are too soft for you, too.
Fupped Duc is offline   Reply With Quote
FS: 996 Ohlins Rear Shock mito_gp Parts and Accessories 1 Mar 16th, 2011 10:01 pm
WTB: Ohlins rear shock for 03/04 **9 ALephart Parts and Accessories 0 Dec 28th, 2010 7:46 pm
F/S: Ohlins rear shock for 749/999 delirious Parts and Accessories 4 Jul 20th, 2010 10:49 am
Ohlins rear shock eye to eye Gizmo Sport Classic 5 Aug 15th, 2008 12:33 pm
Ohlins rear shock Tothna Superbikes 3 Apr 23rd, 2008 3:44 pm
