Cheese with my "Whine" - Ducati.ms - The Ultimate Ducati Forum
Old Dec 2nd, 2011, 6:27 pm   #1 (permalink)
I am trying to diagnose a problem with my new to me 2010 Multi Sport. I haven't even had a chance to ride it yet. After the regular ignition noises, a high pitched whine continues from the TPS area. Conveniently, it didn't make such a noise when I picked it up a few weeks ago. Unplugging the large connector on the left side visible through the trellis stops the noise and throws a TPS code. The whine is controlled in both pitch and volume by moving the throttle. Unfortunately, I am a ferry ride away from my dealer and they suggest that it may be a noise inherent in the ride by wire. It is just too loud and unusual to be normal. Obviously they need to see the bike for an accurate diagnosis but I was wondering if anyone here had any ideas. Multis are pretty rare in my area so I don't have another to compare it to. Thanks for your input.
bcmonster is offline   Reply With Quote
Old Dec 2nd, 2011, 7:01 pm   #2 (permalink)
I'm just across the pond in Tsawwassen if you want to compare bikes.
ps I don't hear the same thing on mine. The only "high pitched" noise I hear is the fuel pump bringing the system up to pressure before starting the engine.
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Dec 2nd, 2011, 10:18 pm   #3 (permalink)
Thanks for the offer! I get the normal pump sound but this one sounds similar to a stuck relay. Just not right. My only worry about picking up a bike in Vancouver was going back for service and it sure doesn't appear I will have to wait too long.
Old Dec 2nd, 2011, 11:50 pm   #4 (permalink)
pm me if you like, and I'll meet you at the ferry and ride down to the shop with you.
R.I.P. #58
Old Dec 2nd, 2011, 11:55 pm   #5 (permalink)
Mr Sunshine's Avatar
The high pitch whine is normal. It is the throttle servo motor. There was a long discussion on it when the bike first came out. Search.
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Dec 3rd, 2011, 8:59 am   #6 (permalink)
I've always assumed the whine was from the cam belts. My two previous Ducs have made this noise. So did my old ST1100.
mollycbr123 is offline   Reply With Quote
Old Dec 3rd, 2011, 11:06 am   #7 (permalink)
Thanks Mr. Sunshine. FWIW I do try to do a complete search prior to posting and used TPS, Whine, etc but didn't see anything. I will try again. It is interesting however that I did not have this sound when I first viewed and picked up the bike, only since last week. It is quite loud and maybe/hopefully one of those mysterious sounds that goes away with time. The bike has only 3500 KMs so wasn't ridden much. I have been around alot of bikes and if I was standing beside this one with no knowledge of the bike I would definitely be saying " something is wrong there" Thanks for the replies.
Old Dec 3rd, 2011, 11:55 am   #8 (permalink)
OK maybe I am an idiot but I am unable to find any threads regarding this question. Almost am scared to ask Mr Sunshine, but can you point me in the right direction please?
Old Dec 3rd, 2011, 1:00 pm   #9 (permalink)
Actually, Ian, I have followed this site for years and I have not heard of this complaint before so you may not find any earlier threads.
R.I.P. #58
Old Dec 3rd, 2011, 4:46 pm   #10 (permalink)
Drs
Hi bcmonster,
Got my MTS today and had to replace the battery (2nd hand bike). After a short ride, had to change DTS settings at which point I noticed 'the whine'. Definitely not normal! I haven't checked to see if it changes with throttle, will do so tomorrow. Noise is coming from right hand side of the bike (btw what is the TPS?). Hope there is an easy fix... Could have sworn it wasn't there before I changed the battery (which wasn't completely flat, but couldn't swing the starter).
Ok, had some time to make a clip:
- you'll hear the sound going away when I press on the bracket. It's almost like something is preventing it from being completely closed?!
2010 MTS 1200 ABS
2008 BMW R1200GS
1993 Suzuki RGV 250
Old Yamaha DT 175 Enduro
Older Honda MT-5
1983 Yamaha PW50
Drs is offline   Reply With Quote
2012 Ducati superbike: "R version" = "Rossi Button" CAlexio Ducati Motorcycle Chat 45 Jan 26th, 2011 5:09 pm
Strange "whine" coming from rear axle. Dealership found nothing. Matt_P Superbikes 12 May 24th, 2009 8:11 pm
900ss '97 i'm looking for "clear front turn covers" and "frame slider kit" pompone italy Supersport 9 Aug 12th, 2008 10:17 pm
"Ducati hits the AutoBlog" or, "Fanning the Flames of the redesign rumor mill" fasterdammit Monster 4 Oct 1st, 2007 8:23 pm
