Termi exhaust - sick puppy - Ducati.ms - The Ultimate Ducati Forum
Old Nov 30th, 2011, 11:46 pm   #1 (permalink)
I was trying to figure out why my 1198 sounds like King Kong and my multi sounds like a puppy. Both have Termis so I took a few rough measurements.
Headpipe ID------Multi 2.10" (53.3 mm) 3.46 sq. inch
1198 2.155" (54.7 mm)
Collector ID------Multi 2.460" (62.5 mm) 4.75 sq. inch
Muffler ID--------Multi 1.70" (43.2 mm) 2.27 sq. inch
1198 2.01" (51 mm)
Muffler Length----Multi 19" (483 mm)
1198 13" (330 mm)
It appears as though this may require surgery on the muffler. It needs to be opened up and shortened. Has anyone already done this?
Rat Patrol is offline   Reply With Quote
Old Dec 1st, 2011, 2:24 am   #2 (permalink)
Mr Sunshine's Avatar
Yes there is a thread on it in here.
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Dec 1st, 2011, 12:21 pm   #3 (permalink)
ddd269's Avatar
I had my Termi cut by my local muffler shop. It's a straight forward job. If you want to do it yourself, here's a link with instructions. http://www.motorcycleinfo.co.uk/inde...pageId=1589737
2011 Diavel Carbon Red - Full Termi, Fatduc.
2011 Multistrada 1200S Sport, White - Full Termi(shortened), Fatduc, GB 14T front sprocket, GB silicone hose(race version, no thermostat), 100 N/mm rear spring, PP windshield, rLink GPS Alarm, lots of gold bling.
2007 Yamaha Vstar 1300
2005 Suzuki GSXR750
2009 Suzuki Hayabusa (gone)
ddd269 is offline   Reply With Quote
Old Dec 1st, 2011, 12:25 pm   #4 (permalink)
ddd269's Avatar
It's not that much louder than the original length. I like the look more than anything else. It does get a bit more hot so don't stick the Termi sticker too high up. Upper portion of thermal Termi sticker melted because of the heat. I ended up sticking a smaller one lower and had not had any problems melting.
2005 Suzuki GSXR750
Old Dec 1st, 2011, 2:34 pm   #5 (permalink)
Somewhat related question: Anyone have a source for an "arm" to hold the Termi can on if you take off the passenger footpegs? That footpeg bracket is always in the way of my heel and my bags are off 90% of the time so this would be an easier and cheaper solution than buying another Termi footpeg bracket and chopping it up. TIA...
Buckeye is offline   Reply With Quote
Old Dec 1st, 2011, 2:46 pm   #6 (permalink)
The reason your 1198 and your Multi sound so different has little or nothing to do with the muffler.
The issue is valve overlap. The Multi has 11 degrees of overlap (hence the "Testastretta 11 degree" on the sidecase), while the 1198 has 41 degrees of overlap.
Short of putting the cams out of an 1198 in your Multi (and I have no idea if that's even possible), you're not going to get that trademark Ducati 'thump' you feel in the center of your chest out of the Multi. Which is a shame, because that's the best noise in motorcycling as far as I'm concerned.
2011 Multistrada 1200S Touring
2001 HD Dyna FXD(X)
kglesq is offline   Reply With Quote
Old Dec 1st, 2011, 9:36 pm   #7 (permalink)
Flunking Social Studies
jackaus's Avatar
+1
My 2 cents,
I have a 999R with 57mm full race termi and ECU. It sounds like a slutty, mean, angry pro dragster staged up fixin to set somebody's doors for em. (sorry, that bike brings out the worst in me)
Multi S with the full Termi etc... Sounds like an exotic trail bike on steroids and blow.
Totally different due to valve actuation/timing. IMHO.
2011 MTS1200 touring AKA Moonlight
2005 999r
1999 748
1993 900ss (gone)
1991 900ss (gone)
Austin, Texas
jackaus is offline   Reply With Quote
Old Dec 1st, 2011, 10:34 pm   #8 (permalink)
Overlap and Compression
I agree, but when you're raised on this................................
[IMG][/IMG]
the puppy dog bark doesn't cut it. I think this termi was designed for a different demographic than me. The termi on the Diavel sounds a lot meaner, probably because they are very short. I have to give it a try, it's in my blood. Thanks guys for the input.
Old Dec 1st, 2011, 11:21 pm   #9 (permalink)
Very Good Link
Originally Posted by ddd269 View Post
I had my Termi cut by my local muffler shop. It's a straight forward job. If you want to do it yourself, here's a link with instructions. Motorcycle Info Pages - MTS1200 DIY Mods > Full Termi Cut Down!
Great article, thank you for the link.
Old Dec 2nd, 2011, 2:19 am   #10 (permalink)
TiDuc's Avatar
I am in the process of building a full Titanium system for my Multi… I found is the Diavel uses larger head pipes (58mm if I remember correctly) and also has equal length pipes as well. I did increase my head pipe size for the Multi to match the Diavel and am still struggling to fit equal length pipes under it. The can is going to take a lot of experimenting to get the correct volume and fit it where I want it. I think the larger head pipes and volume of the muffler will change the Tone of the multi significantly, but I think the others are correct about the cam timing making a difference in the sound/feel of a multi, especially at idle. Possibly some advance of the stock cams might change it’s attitude??? Now, if only somebody knew if 1198 cams would swap. Maybe one day I’ll have time to head down that road….I hope very soon to have the bike running on the new exhaust…I pick up the new argon bottle today!
Pisa, Italy
2011 Multistrada
NSR250R
H2 Kawi 2-stroke triple
CBR900RR (Gone)
CBR600RR (Gone)
many others long gone...
TiDuc is offline   Reply With Quote
MS 1200 exhaust options- full Termi vs Termi can only fixinbones Multistrada 198 Jul 22nd, 2010 9:13 am
My 748 is a sick puppy keef Superbikes 2 Apr 7th, 2010 3:27 pm
AKRAPOVIC EXHAUST OR Termi exhaust? for 03 999S nysid2007 Superbikes 21 Apr 6th, 2009 4:14 am
ok, i'm sick of it, i need exhaust help!!!!! ducati955 Superbikes 17 Apr 3rd, 2007 1:24 pm
