Cam belt idler bearings (1100)
Having a noise from the right side of the engine (only when warm) that sounds like a ball bearing issue. To me, just from listening at idle, the frequency of the growl sounds like it would be associated with the cam rotating speed which is not particularly encouraging. But the belt idlers show some sign of corrosion. I did try to home in with the screwdriver against the ear trick but that wasn't particularly conclusive. My plan is to replace the idler bearings anyway and see if that fixes it. I haven't taken her apart yet and had a couple questions that I could use some help with in preparation:
1) Bearing P/N. Some variations out there for recomended SKF replacements. Options like bearing clearance and seal type. Does this application use a "normal" or a "C3" spec clearance bearing?
2) How many do I need? Can all four idler wheels be re-bearinged (some confusing guidance out there)? Is there one or two bearings per idler?
Thanks, Reno
