DP c/f rear hugger on an MTS12? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 13th, 2011, 12:41 pm   #1 (permalink)
Has anyone installed the DP c/f rear hugger on an MTS12?
I have this part, but it didn't come with any hardware and the hardware for the stock plastic hugger doesn't fit.
Did you have this problem?
'10 MTS 1200S
'08 Brutale 910S
'06 KTM 950SM
'95 900SS-SP
curvesurfer is offline   Reply With Quote
Old Nov 13th, 2011, 4:54 pm   #2 (permalink)
JimmyVee's Avatar
Hi curvesurfer, I fitted the dp rear hugger but had to use my own screws as the dp hugger does not come with the holes drilled out to the correct size. Have a few dp parts and they are all the same.....wrong size pre-drilled holes.
JimmyVee is offline   Reply With Quote
Old Nov 13th, 2011, 4:59 pm   #3 (permalink)
Thanks Jimmy. That helps confirm I'm not missing something...
One would think the c/f part would be from the same template as the stock piece, but I guess not!
'10 MTS 1200S
'08 Brutale 910S
'06 KTM 950SM
'95 900SS-SP
Old Nov 13th, 2011, 11:50 pm   #4 (permalink)
+1. I had to go out and dig up my own mounting hardware too. Many write it off as typically Ducati but c'mon...is hardware too much to ask for such a crazy expensive add-on?
'12 Triumph 1050 Speed Triple R w/Full Arrow 3-1 Exhaust System
'10 Ducati Multistrada 1200S Touring w/full Termi Exhaust System & (Redline) Power Commander V
'06 Triumph 1050 Speed Triple w/Leo Vince system (traded 5/17/12 for a new S3R - yes, it was that good)
'04 Kawi KLX125 (play & ice bike)
2WheelsRBetter is offline   Reply With Quote
Old Nov 14th, 2011, 12:06 pm   #5 (permalink)
it's even more aggravating because the 3 bolts used to attach the hugger are not the same size....1 is different than the other 2 for no apparent reason.
viva italia!
'10 MTS 1200S
'08 Brutale 910S
'06 KTM 950SM
'95 900SS-SP
Old Nov 14th, 2011, 2:09 pm   #6 (permalink)
MTScott2's Avatar
Images: 5
Yeah Welcome to Ducati...
I wonder if Shift Tech does it better ,
you would think the workers at the Ducati Botique would tell you that you need Hardware ,also to save you a trip..
Just like removing the belly pan , USE all the same fasteners , what's with 2 different sizes???
Hows the finish ? I have seen some and it looks like there are different degrees of shine or lack of , I know it should not matter but it would be expected to have Very Close to the same looking end product...
QUALITY CONTROL issues...
2011 Red Multistrada Touring
MTS12: rear brake reservoir bolt gone curvesurfer Multistrada 6 Apr 6th, 2011 3:52 pm
WTB: Rear Hugger newguy Parts and Accessories 2 Apr 6th, 2010 11:39 pm
Looking for rear hugger jjewell Sport Classic 6 Dec 3rd, 2009 12:04 am
Rear Hugger Hammerman Sport Classic 31 Jul 30th, 2008 7:48 pm
Rear Hugger hotflashjr Sport Touring 3 Feb 17th, 2006 5:24 pm
