Emissions canister delete. - Ducati.ms - The Ultimate Ducati Forum
post #1 of 9 (permalink) Old Oct 22nd, 2011, 7:13 pm Thread Starter
Easty's Avatar
It caught my eye on the way into the garage for the last time today..
It's a really easy mod.. Took about 30mins.
Before
An English Alien!
Cultivated so far
Altrider Header Guard(anodized black), Altider Water pump protector, Altrider Cameltoe, IU-27 Nippo Denso plugs, Auto Fuel Cap, Heated grips,DP Panniers.
I'm in heaven with 0 97
2012 Multistrada Pike Peak #097
2008 1098
SLK 55 ///AMG
Easty is offline
post #2 of 9 (permalink) Old Oct 22nd, 2011, 7:58 pm
How the heck do you get to the hose clamp on the rear cylinder?! That's the thing that's been stopping me...suggestion?
dudecati is offline
post #3 of 9 (permalink) Old Oct 22nd, 2011, 8:00 pm
Turkishexpress's Avatar
I like it. What is the purpose of the canister anyway?
KTM Super Duke 1290R / 2011 Multistrada S Touring (Sold) / K7 600 (Track Only)
Turkishexpress is offline
post #4 of 9 (permalink) Old Oct 22nd, 2011, 8:15 pm Thread Starter
Easty's Avatar
Why do you need to just take the hose off the top of the cannister and put a vacuum blank on it.
then Just splice the feed pipe to the original drain pipe and wrap them both both of the way.
It takes the vapor from the tank and filter it through a carbon filter then the engine sucks it back in to be burnt.
It's not on the Euro bikes and not legally required outside of CA.. the just obviously bolted it on as an after thought. instead of making a unique CA bike, just made them all the same.
Uk multistrada's
An English Alien!
Cultivated so far
2008 1098
SLK 55 ///AMG
Easty is offline
post #5 of 9 (permalink) Old Oct 22nd, 2011, 8:43 pm
Aaah, good deal.
post #6 of 9 (permalink) Old Oct 23rd, 2011, 3:15 pm
jfusaro's Avatar
Mine came off the day it came home.
jfusaro is offline
post #7 of 9 (permalink) Old Oct 23rd, 2011, 4:12 pm
The Strebel Nautilus horn fits perfectly in the space where the cannister was- and is a heck of a lot more useful!
TwistedThrottle.com : Stebel Nautilus Compact Dual-Tone 12-Volt Motorcycle Air Horn, 139 dB, Black or Chrome - Stebel
drdave39
Treating life, one twisty at a time...
2010 Multistrada 1200S Touring- "The White Shadow". Lowered, re-sprung, and Tuneboy-ed!!
2004 Multistrada 1000DS, lowered and Ohlins'd- gone, but you never forget your first...
drdave39 is offline
post #8 of 9 (permalink) Old Oct 23rd, 2011, 8:41 pm
jfusaro's Avatar
Just to be clear when I did mine I plugged the tube coming from the throttle bodies. I left the T in the line and plugged the single line on the left side. I then connected the larger hose that goes up to the tank, I assume its the overflow because I cant see where it attached to, and used the remaing hose off the bottom of the cannister to extend it down and away from the header. I am thinking the cannister is there to catch overflow from the gas tank inner rim and the fumes get pulled into the throttle bodies when the engine is running.
jfusaro is offline
post #9 of 9 (permalink) Old Oct 23rd, 2011, 9:04 pm
robb's Avatar
drdave,
Can we see a picture of how you installed the horn? I'd like to do the same - I'm tired of the 'road runner' cartoon sounds that the stock horn makes. Also what else did you need for the install - L bracket, wiring harness?
thanks!
___________
'13 MV Agusta Brutale 1090RR
'06 Sport 1000 Ohlins/Zard
'10 MTS 1200 S Sport/Touring
'06 ST3S (sold)
'08 S4RS #199 (sold)
'08 Husqvarna TE610
robb is offline
Human Verification
Removing the Evaporative Emissions Canister Motoman_AZ HyperMotard 149 Mar 13th, 2017 9:12 pm
Emissions canister wilson59 Multistrada 3 Oct 2nd, 2010 3:51 pm
Emissions canister canisterectimy 07Sport1000S Sport Classic 5 Oct 19th, 2009 7:29 am
So that emissions canister... TiltTheHorizon Sport Classic 10 Oct 6th, 2009 8:20 pm
Ca Emissions Canister? RAMM241 Sport Touring 5 Mar 4th, 2007 3:29 pm
