MTS1200 Cruise control from the factory - Page 50 - Ducati.ms - The Ultimate Ducati Forum
post #491 of 1006 (permalink) Old Mar 4th, 2013, 4:56 am
wcieslik's Avatar
Originally Posted by drdave39 View Post
Mine arrived but bike is still at dealer awaiting new tank (weather sux anyway)...
QUESTION FOR THOSE WHO HAVE INSTALLED CRUISE WITHOUT NUDGE BUTTONS-
is there any interference with the heated grip control? They both use the starter button and I'm trying to figure out if there might be a problem. If so I need to order the nudge button ASAP...
Dave
Dave.
Turning CC on requires a long press of the button. this wont affect heated grips other than bringing the heater menu up.
Be aware though, that if your CC is aleady on, then operating the grips will set and engage CC. The manual suggests that if you want to adjust heated grip while CC is on, perhaps pull and hold the clutch. then adjust grips, release clutch and re-engage CC if required. It will become 2nd nature very quickly.
If you have the nudge button tune... remember to disconnect your O2 sensors !
+1 for Tuneboy V4 and MultiTool for Android.
1200 S Touring. 79,200 km traveled since August 2010...
wcieslik is offline
post #492 of 1006 (permalink) Old Mar 4th, 2013, 6:21 am
Originally Posted by Humpo View Post
All you have to do is pull in the clutch and hold it in then change heat settings them realise the clutch. The first time is a bit hard but you get good at it quickly. The nudge buttons are sooooooo good you will want a set anyway.
Oh- that makes sense- clutch in disables the cruise mode!
The buttons look nice, but that side of the bar is already crowded with GPS and radar...
drdave39
Treating life, one twisty at a time...
2010 Multistrada 1200S Touring- "The White Shadow". Lowered, re-sprung, and Tuneboy-ed!!
2004 Multistrada 1000DS, lowered and Ohlins'd- gone, but you never forget your first...
drdave39 is offline
post #493 of 1006 (permalink) Old Mar 4th, 2013, 10:12 am
Dr. Greg's Avatar
Tailwind and cruise control performance
I've had the Tuneboy CC working since last Christmas. Yesterday was my first opportunity to ride it in a strong tailwind (early spring in New Mexico USA)...quite an influence.
The CC "behaves" better (i.e. no oscillation) in headwinds; a headwind seems to provide a little damping which stabilizes the system. A bit of a disturbance for it to "work" against, if you will.
But in a tailwind, it's pretty bad. Speed up, slow down, speed up, slow down...classic unstable behavior. Almost annoying enough that I disabled it (but I didn't).
Don't get me wrong...I LOVE the cruise control. It's the best money I ever spent on that bike. But its behavior is not quite perfect. I feel the gains could be tuned a little better.
--Doc
Dr. Greg is offline
post #494 of 1006 (permalink) Old Mar 4th, 2013, 10:42 am
Gilles's Avatar
Originally Posted by gabeschine View Post
It's back more than 6 pages, but here's the link:
http://www.tuneboy.com.au/DucatiMaps.php
as far as I can tell, they are exactly the same as the ones on the CD.
I'll soon be uploading this now that spring is almost sprung here in Denmark.
It seems the product is much better than its instruction set....
2010 1200 Multistrada S Touring Black
2008 Termi S4R
Upgraded to S4Rs following wreck
BST wheels
Gilles is offline
post #495 of 1006 (permalink) Old Mar 4th, 2013, 12:59 pm
Actually, it's not really that bad. My CD was cracked in the package so I didn't have the link for the maps or FlashMitsubishi program and couldn't find on the Tuneboy site on my own.
That said, if you follow the directions in this doc (http://www.tuneboy.com.au/TuneBoy_MTS1200_Diavel.pdf) you should have no problem at least flashing (I didn't do any live tuning).
I used the USB connection so did load the drivers. Honestly, the longest time took just installing the nudge buttons - at that was where to run the wire. I saw no good way of running under the tank without having to lift/remove the tank so I did it between the tank and he left fairing. Can't tell at all when everything is back on the bike, not sure what others have done.
If you have any questions - feel free to ask since I just did the install. I can send more pics of under the seat as well since this was also a bit confusing - there are a LOT of connectors there!
Steve95628 is offline
post #496 of 1006 (permalink) Old Mar 4th, 2013, 3:39 pm
Just curious... where do you gents mount the wi-fi unit?
2011 Ducati Multistrada 1200 S Touring
2008 Ducati 848
(SOLD)
2008 Honda Shadow Spirit 750 CS2 (SOLD)
Cerberus is offline
post #497 of 1006 (permalink) Old Mar 4th, 2013, 7:54 pm
Official Sponsor
motodisiac's Avatar
You do not have to mount it, after the re-flashing is done you disconnect it and keep it in a safe place for future use.
If you are using it for data logging, just leave it under the passenger seat.
D.
Beach Moto - Ultimate Motorcycle Gear Online and in Los Angeles
Ducati Multistrada 1200S - Adventure, Track, Commute, Dirt, Fun
Honda CRF450X - Fun, torture, fun.
motodisiac is offline
post #498 of 1006 (permalink) Old Mar 4th, 2013, 10:36 pm
D.
Thanks! I was contemplating keeping it hooked up just b/c of the logger feature, but since it's compatible with Android yet, I probably will just flash the ECU and remove WiFi.
2008 Ducati 848
(SOLD)
Cerberus is offline
post #499 of 1006 (permalink) Old Mar 5th, 2013, 7:17 am
TiDuc's Avatar
Motodisiac,
way back in Dec you got your Tuneboy and said you were going to be using the tuning function, and review it...Curious about your experiences with it. Have you had a chance to use the tuning function yet, and care to share your experiences?
I keep chasing postal trucks looking for my package from Australia, maybe your review can distract me for awhile.
2011 Multistrada TUNEBOY equipped Dry STM slipper clutch... and some tricky bits inside the motor
W/Real Ohlins manual TTX shock and 30mm TTX cartridges & BSTs
TiDuc is offline
post #500 of 1006 (permalink) Old Mar 5th, 2013, 10:17 am
GiLL's Avatar
After spending a few days at the local post office my kit finally made it home yesterday afternoon... :-) install and my review will be soon to come.
GiLL is offline
Human Verification
cruise control options? DeBenGuzzi Sport Touring 4 Dec 14th, 2010 11:02 pm
Cruise Control update red&gray Supersport 0 Jul 17th, 2010 11:33 am
cruise control for SF uchira StreetFighter 2 Jun 14th, 2010 8:34 am
MC Cruise Control keydiverdown Sport Touring 38 Oct 6th, 2008 10:53 pm
Cruise Control HELP!!! Oilhed Sport Touring 13 Jun 30th, 2008 4:50 pm
