No Power at all... Main fuse location on 696? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old May 4th, 2010, 8:09 am Thread Starter
VR-4-Life's Avatar
Unhappy No Power at all... Main fuse location on 696?
Hello all,
I installed a tail chop and blew one of my blue fuses... I replaced the blue fuses but I still dont have power. Is there a main fuse on the bike, if so, where is it located? I've heard of them on other models, but I cant find anything in the manual besides the 30 amp by the ECU for the regulator.
The strange thing is.. when I finished the tail chop, my bike started, stalled with the CEL on, and did the same thing after restart. after that it wouldnt start. will the bike throw a CEL for a short?
I was pretty careful to avoid arching power, but I guess the sheilding stripped off a wire back there.
Any help would be appriciated... my tail chop is done, and now I want my bike to turn on
09 Red Monster 696, Termi CF kit, HID, Tail chop...
VR-4-Life is offline
post #2 of 3 (permalink) Old May 4th, 2010, 11:21 am Thread Starter
VR-4-Life's Avatar
bump.. 15 views and no help... Does anyone know where the main fuse is?
post #3 of 3 (permalink) Old May 7th, 2010, 9:27 am
Stick's Avatar
Seems like Ducati is using the 30 or 40A (large) fuse as a "main fuse" in the last few schematics that I looked at. (This was on a 1098, 1198, and 848--I was looking at the U.Manuals that you download on-line for info on the alternator sizes.)
Anyway, DUC used to use the big fuse as just a Reg.Rectifier fuse, but as I mentioned, it looks like they use this fuse as a main, now. Also, it appears that on these SBK machines, that this fuse is now placed right on the starter solenoid.
Maybe the "new" Monsters are like that. That's where I would start looking. Shouldn't be too far from the battery.
Stick -~~~- Need an adrenaline rush? Shove a DUC between your legs.
Present DUCs: 2003 ST4S, 2001 ST2, 1996 900 SS/CR
Stick is offline
Human Verification
Main Bearing preload ian996 Supersport 16 Jan 25th, 2015 10:06 am
Fuse box location on Hyper hyperd1 HyperMotard 2 Jan 6th, 2010 4:49 pm
Main beam not working Daniel Monster 6 May 6th, 2008 3:43 pm
Crank main bearings 99 996 kiwikev Superbikes 0 Nov 14th, 2007 2:31 am
Power outlet fuse question PookaDog Sport Touring 8 Jan 26th, 2006 11:41 am
