Intro and a few S4RS questions - Ducati.ms - The Ultimate Ducati Forum
post #1 of 33 (permalink) Old Jan 6th, 2017, 8:55 pm Thread Starter
Hello everybody!
I have been riding Ducati Superbikes for the past 20 years and finally made it to my first Monster, a pre-loved '07 S4RS with 9000mls (full Arrow CF system with DynoJet module), 3-4 year old tank.
The 6000mls service was done by the dealer about 3 years ago.
Beside the typical fluid changes, valve check and belts, are there anything Monster specific items/topics I should check/do?
In particular, my concern are about the replaced gas tank, which doesn't show any signs of defects, how do I preserve it and the DynoJet module.
Thanks for sharing your knowledge!
draganc is offline
post #2 of 33 (permalink) Old Jan 6th, 2017, 9:10 pm
Images: 4
Welcome, draganc. I also have a white 07 , quite new to me as well. Mine had never had ethanol in the tank according to PO. I ran out due to the amazingly poor fuel mileage and had to use ethanol laced fuel to get home. Though I meant to run it out quickly it didn't happen for about two weeks . My tank had swollen about 3/8" . After several tanks of non ethanol it shrank back, but it took the rest of the summer. If you have to use ethanol, use it up asap.
Other than that I can't add much to your list, except to set up the suspension for you and don't trust the PO. Mine was all screwed up.
Great bike, isn't it ?
Jewcati likes this.
duc96cr is offline
post #3 of 33 (permalink) Old Jan 6th, 2017, 10:13 pm Thread Starter
Swollen 3/8", that's just crazy!
Did you use any of the fuel stabilizer? Does it even help?
This must be Ducati's worse F-up ever.
I test rode the bike for about 10min at 40deg and I loved it.
I love those Ohlins from my R.
draganc is offline
post #4 of 33 (permalink) Old Jan 7th, 2017, 1:29 pm
Images: 21
Stabilizer will not help, just like he said do not let E-10 sit in tank. I've been running Non e-fuel in my sport classic ever since I got the tank replaced, still just like new. 2 tanks of e-10 and original tank was falling off the pucks up front.
'77 RD-400
'03 FLSTF
'06 Sport 1000 Yellow
'04 XL1200R
'07 999s
jcasella is offline
post #5 of 33 (permalink) Old Jan 7th, 2017, 3:02 pm
Moderator in moderation
mlukason's Avatar
Just curious jcasella, since we're neighbors: where did you find gas without EtOH?
Mike
2006 ST3 - 2004 KLR 650 (the Truck)
NEDOC
mlukason is offline
post #6 of 33 (permalink) Old Jan 9th, 2017, 2:06 pm
Images: 4
There is a website called " Pure Gas " which will tell you most, but not all, of the places in your area to purchase ethanol free gas. Expect to pay about 30% more for 10% more gas. My math may be a little rusty, but....
duc96cr is offline
post #7 of 33 (permalink) Old Jan 10th, 2017, 1:34 pm
bcandback's Avatar
I've heard of guys lining the inside with caswell? I had an 07 s4rs white/red. Wish I never sold it.
2003 ST4S
2011 Multistrada 1200 S Touring
Bimota DB5 Mille
Reno, NV
bcandback is offline
post #8 of 33 (permalink) Old Jan 10th, 2017, 1:53 pm
Official Sponsor
SPORT_CLASSIC_SPECIALTIES's Avatar
This has been an ongoing issue for the Sport classic, MS and Monster.
Heat cycling of these tanks will expand and contract as much as 1/4 inch under sunlight and or heat from the Bike.
This will cause some deformation.
It is really hard to pinpoint why plastic tends to deform over Steel, aluminum, or fiber
If the tank is removed and washed out and left out to dry or have air circulated through it. We have found the Sport classic tank will contract or shrink back.
Can take anywhere from 1 week to 2 months.
It is almost like a lifeform.
Caswell is only as good as the prep work to install it. Prep is 95% of it.
It is also a tool used to "extend" the life of the tank and not a cure. Expansion may still occur due to heat but can help with reinforcement to keep the shape. It will help with keeping ethanol from leaching it to the tank surface to cause bubbling or pimpling of the paint.
We use a special rotation machine and special aggregate to rough up the inner surface for the epoxy to have something to attache to.
See here for loads of info
Out Of Warranty Spreading Tank Problems
The service we offer cost $400
If you can get a new tank I would coat it right away
If you can find a good used that that has shrunk back or decreased in swelling it is a good idea to coat it. If you plan to repaint cost it first then have it painted.
If it has been painted or has stock paint we can protect it.
jc@jcpakbikes.com
sportclassicspecialties.com
JCPAKBIKES.COM
FACEBOOK JC/PAK BIKES
FACEBOOK GT1000
FACEBOOK PS1000LE
FLEDA TRON LEGACY
ALPINA WHEELS USA
AELLA-CASUNO / NCR / DISCACCIATI / CARBON DRY / BITUBO / MUPO
SPORT_CLASSIC_SPECIALTIES is offline
post #9 of 33 (permalink) Old Jan 11th, 2017, 2:48 am
Heath's Avatar
If the tank is not showing any signs of expanding it only means two things. One the previous owner avoided ethanol at all times. Or two it is already coated. If you are having trouble finding ethanol free stations or plan on doing trips where there are none I'd get it coated quick.
My S2R800 expanded and I had it replaced. Second one expanded and the dealership drug their feet to officially file a claim and said "oops, too late" This was all before caswell was well known as a bandaid for the problem.
I purchased my S4RT with a coated tank and I keep a close eye on it. Should the caswell start to fail at anytime I will drain it as fast as I can to get it re-coated. If I ever come into a lot of cash to blow I'll buy a metal tank and be done with the whole problem.
2007 Ducati Monster S4RT
2006 Ducati Monster S2R800 Dark [sold]
Heath is offline
post #10 of 33 (permalink) Old Jan 11th, 2017, 12:23 pm
Images: 21
I keep a 35 gal drum of e-free VP fuel, expensive AF but I only ride this duc on Sundays so I'm able to pull it off. The website shows the whole NE area as unable to get ehtanol free anywhere that you could drive to. Have to know a private pilot to get it at most airports, easier to order the barrel of this direct, runs me through a summer.
'77 RD-400
'03 FLSTF
'04 XL1200R
'07 999s
jcasella is offline
Human Verification
Intro jasminew14 Welcome and Introduction 1 Jun 10th, 2016 1:33 am
Intro after YEARS of lurking McLovin Welcome and Introduction 1 May 26th, 2016 1:01 pm
Intro post tdean44 Welcome and Introduction 1 Apr 24th, 2016 6:53 am
New member intro! jaehan521 Welcome and Introduction 1 Feb 24th, 2016 8:48 am
intro Koeffoet Welcome and Introduction 2 Jan 8th, 2016 1:17 pm
