696 maintenance - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsSportbikeTrackGearMotorcycle.com Classifieds!
Old Jul 14th, 2008, 4:45 pm   #1 (permalink)
696 maintenance
is it safe to say, from the looks of it, that the belt can only be adjusted by dropping the whole engine down? Kinda poor design if you ask me, because thats just more work for dealership and more money to charge
Otherwise, I love this bike, the looks, feel, plenty of real world power especially with a 14t sprocket change.
Ninja 650R
M696 In Faster White!
calibretto is offline   Reply With Quote
Old Jul 14th, 2008, 4:47 pm   #2 (permalink)
Did you do the 14T sprocket or have it done?
sroberts152 is offline   Reply With Quote
Old Jul 14th, 2008, 5:08 pm   #3 (permalink)
Had it done, I don't have access to the tools and space needed to work on it.
Took just under half an hour for the dealer to do, and was well worth it
Ninja 650R
Old Jul 14th, 2008, 5:10 pm   #4 (permalink)
Got it.
Has anyone done this? Am I crazy to try and undertake this?
Old Jul 14th, 2008, 6:04 pm   #5 (permalink)
really easy, all you need is a couple of allen wrenches and a 10mm wrench (i think)
Loosen 1 side of your axel,(pref left)
loosen your chain
remove cover plate from sprocket
remove bolts from sprocket
remove clip from splines
remove clutch boss (it is a sealed system you wont need to bleed it later)
If you dont have a rear stand you will need a second set of hands
Loosen the 2 lower bolts from your clipon and you should be able to slide the sprocket off and the new on and repeat to put it back on. You should be able to do it
AKRider is offline   Reply With Quote
Monster 696 Accessories up! desmoworks Pro Italia/Desmoworks 9 Oct 15th, 2008 12:35 pm
2007+ Ducati Maintenance schedules/costs revealed Nitrouz Superbikes 12 Nov 16th, 2007 5:15 pm
Where can I get the maintenance schedule for my ST3s? gregcm Sport Touring 3 Aug 25th, 2007 7:41 am
Maintenance 50% cheaper on all 2007?? Patou Superbikes 15 Feb 1st, 2007 11:42 pm
Help reseting the maintenance light with VDSTS? nanuk Supersport 2 Jun 11th, 2006 10:54 pm
