14 Tooth Sprocket - Page 4 - Ducati.ms - The Ultimate Ducati Forum
Old Jul 4th, 2012, 3:00 pm   #31 (permalink)
Originally Posted by something_witty View Post
How much top speed to you loose? Anyone test it out yet?
I have 2012 796ABS
I didnt loose any top speed as the bike has an easier time pulling the shorter gearing. In fact, i recently hit 133 on a straight i previously hit 129. The bike takes forever(or downhill) to pull the last mph anthow and theres knowhere on the street ur gonna notice the top speed change. The quicker acceleration and ease of pulling from uphill stops makes it totalled worth it.
Its easy todo. Theres know reason to pay a shop an hours wage unless u dont have any tools( or buddies w tools). Loosen the chain significantly. Undo the big bolts that hold the rearset in place and turn it so its outta the way. Take off the plastic trim and metal cover. Remove the clutch slave cylinder... Bend the tab up on the washer on the sprockets nut and hit the nut w an impact wrench to loosen/remove... Put it back together in reverse. No chain links need to be removed, theres plenty of adjustment available.
I agree with others who said ducati should have sold the bikes to us like this. I havent noticed any fuel mileage changes either.
2008 ducati hypermotard1100 w/ s4rs monster tank and seat. Custom subframe and batterybox.14 tooth front sprocket, K&N pods, cat eliminator w two brothers can and retuned ecu. Dual 4" headlights and buell xb flyscreen...
Previously:1999ktm motard, 1997ktm motard, 1996ktm duke, 1989 honda rc31(hawk650gt) w/gsxrforks,cbr900shock,vfr rearwheel and rvf/rc30 bodywork(my first bike/project)
booger weldz is offline   Reply With Quote
Old Jul 23rd, 2012, 9:28 am   #32 (permalink)
sanaga's Avatar
Originally Posted by moto View Post
moto
is it direct replacement to my 12 1100evo stock sprocket??
thanks
2012 M1100evo
sanaga is offline   Reply With Quote
Old Oct 1st, 2012, 3:24 pm   #33 (permalink)
jcarruth's Avatar
14 tooth sprocket conversion
Originally Posted by sanaga View Post
moto
thanks
I just did this conversion two days ago. The bike is an 1100 EVO. I can tell a big difference in the machine, especially in 1st, 2nd and 6th gears. I think I am going to keep it this way.
[/SIGPIC]
John Carruth
Medina, TN
jcarruth@click1.net
2012 Monster 1100 EVO
2002 VFR 800 A2
2003 ST1300 A
jcarruth is offline   Reply With Quote
Old Oct 1st, 2012, 9:38 pm   #34 (permalink)
My 0.02c, I just put a 14T sprocket on the 696.
Definitely an improvement, I find the bike easier and more fun to ride with the extra revs, although more gear changes are required.
I found the install pretty easy too, as someone with basic to intermediate mechanical skills.
hobbsy is offline   Reply With Quote
Old Oct 27th, 2012, 9:46 pm   #35 (permalink)
I asked the dealer about the 14t for my 2011 796 after buying it and the guy said I would need that eccentric wrench thing to adjust the chain after I installed the sprocket. Is this true?
jmlenz is offline   Reply With Quote
Old Oct 28th, 2012, 12:05 am   #36 (permalink)
SDRider's Avatar
FYI-Your speedo probably has about 8-9% error in accuracy. It reads faster than you are actually going. When your speedo read 133 you were probably doing 121 at best.
2012 Ducati Monster 1100 EVO
SDRider is offline   Reply With Quote
Old Oct 29th, 2012, 2:26 pm   #37 (permalink)
Jarvicious's Avatar
I have to disagree with the thought that your fuel mileage may suffer. I was routinely getting 40-45 (maaaaybe 45) and the first 120 mile trip I took after the conversion I got 55 both ways. I've heard the same results from people who install (and properly tune afterwards) hi compression pistons. Especially on an anemic bike like our air cooled models, that extra engine power allows the bike to work a whole lot less to achieve the same result.
My top speed went up as well. Discrepancies in speedo accuracy aside, I could eek out a few miles an hour on the top end, most likely due to a few extra hundred RPMs putting me closer to the bikes favorite part of the power band. The damn things are ~$30 and it should take you an hour to do it. Easy Easy.
2005 Ducati Monster S2R 800 with no mods but a shortened ass end
Jarvicious is offline   Reply With Quote
Old Oct 29th, 2012, 4:59 pm   #38 (permalink)
subin's Avatar
Yes, you would need the tool to put the chain back to the correct tension.
subin is offline   Reply With Quote
Old Nov 3rd, 2012, 10:35 pm   #39 (permalink)
thanks Subin
Old Nov 4th, 2012, 3:52 pm   #40 (permalink)
Anyone notice increased chain guide wear with the smaller sprocket? Since I've put mine on about 3000 miiles ago, I've almost worn through the guide near the front. I always keep the chain tightened to spec also (61-63mm).
2003 Kawasaki Vulcan 500
jagibbs is offline   Reply With Quote
14 tooth sprocket Diego.s/f StreetFighter 34 Jul 20th, 2012 5:34 pm
14 tooth sprocket on the 796? Seven9Six HyperMotard 25 Jul 12th, 2012 12:05 pm
WTT, 42 tooth SS sprocket VTGPDUC Parts and Accessories 1 Feb 23rd, 2011 7:06 am
39 to 42 tooth sprocket whitelightning99 Sport Touring 10 Feb 25th, 2010 3:08 pm
14 tooth sprocket Dockstrada Sport Classic 16 Dec 28th, 2007 6:36 pm
