Fuel pump - Ducati.ms - The Ultimate Ducati Forum
Old Jan 25th, 2012, 1:00 pm   #1 (permalink)
Fuel pump
I was curious about the fuel pump variation between the monster 620 and the s2r. I realize the size/ placement varies because of the different composite of the tank. But what I am wondering is if the fuel pump's output is different? Is there a different flow rate/psi between the two?
kittay is offline   Reply With Quote
fuel lines/fuel pumps/fuel pump relay RockingM Sport Touring 12 Aug 9th, 2011 12:15 pm
Faulty fuel pump / fuel level sender wiring TommyGun Supersport 5 May 14th, 2011 7:47 am
Ducati issues a recall for MTS 620, 1000, 1100 fuel pump o'rings, but not fuel tanks Ducatiowner Multistrada 6 Feb 9th, 2011 8:50 am
996 Fuel pump seal and female fuel connector thedjmongoose Superbikes 2 Apr 29th, 2009 2:51 pm
The Dreaded Fuel Line/Fuel Pump Separation Revisited BlackDuck Sport Classic 3 Sep 21st, 2007 5:51 am
