What's best for Cleaning Engine - Ducati.ms - The Ultimate Ducati Forum
Old Jan 24th, 2012, 9:04 am   #1 (permalink)
i want to remove all the bits of oil and exhaust residue from the motor. especially the cooling fins. was thinking that something like Carb - Throttle Body cleaner might do the job nicely. but i am not sure if that might remove any protective coating that is adhered to the motor. can anybody tell me if that cleaner would be safe to use with no risk? or maybe recommend a product that will do the job? thanks in advance. bike is a 2005 M1000s.
raleigh5 is offline   Reply With Quote
Old Jan 24th, 2012, 3:01 pm   #2 (permalink)
simple green or enginebrite degreaser and a toothbrush.
rosstermyer is offline   Reply With Quote
Old Jan 24th, 2012, 3:23 pm   #3 (permalink)
rubber duckie's Avatar
mix half and half of simple green. so far the best degreaser i have found that is safe for you to use. buy a big bottle you will start using to for everything that needs to be cleaned.
rubber duckie is online now   Reply With Quote
Old Feb 16th, 2012, 11:19 pm   #4 (permalink)
Booster's Avatar
Yep, simple green and a brush, rinse well. The waffle is a pain to clean.
Official AxlJak Clutch and Water Pump cover tester. Work Great!
Booster is offline   Reply With Quote
Old Feb 26th, 2012, 8:09 am   #5 (permalink)
timmyho414's Avatar
I've used Zep cleaner which is like simple green and thought it work good.
My brother left some S100 cleaner in my garage for over a year and I got sick of looking at it so I used it. The stuff is awesome. It took off a lot of the grime easily, you still need to scrub if it is thick. To clean off chain lube I use WD-40. Everywhere else the S100 worked get. I swear it left the head of the bolts more shinny. Its says its safe for all surfaces too.
I used it on my Monster.
timmyho414 is offline   Reply With Quote
Old Feb 26th, 2012, 8:50 am   #6 (permalink)
Ducati Acolyte
Warp Racer's Avatar
Images: 5
the S100 detail & wax is excellent as well, for after wash
ONCE YOU'VE HAD ASIAN, YOU WILL NEVER TOUCH CAUCASIAN
OLD AGE AND TREACHERY WILL ALWAYS OVERCOME YOUTH AND ENTHUSIASM
Warp Racer is offline   Reply With Quote
Old Feb 26th, 2012, 9:00 am   #7 (permalink)
oalvarez's Avatar
Motorex works well too....make sure the bike is cool/cold if you decide to use it.
see ya,
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is offline   Reply With Quote
Old Feb 26th, 2012, 10:52 am   #8 (permalink)
I use brake/parts cleaner in an aresol can and a toothbrush. Haven't noticed any ill effect on the paint. I don't use it on the bodywork but the engine and frame are fair game.
Perazzimx14 is offline   Reply With Quote
Old Feb 26th, 2012, 1:18 pm   #9 (permalink)
timmyho414's Avatar
I used brake cleaner to quickly rise something off my motor and it took the paint off the case. I'd be very careful which brand you use. Some are ok others are not.
Old Feb 26th, 2012, 1:27 pm   #10 (permalink)
theWanderer's Avatar
+1 for truth.
theWanderer is offline   Reply With Quote
Suggestions for cleaning a GT engine? confusa Sport Classic 1 Aug 18th, 2011 10:17 am
Cleaning Engine Case mry999eryk Multistrada 1 Apr 10th, 2010 6:43 am
Cleaning the engine and keeping it clean. MHR1000Mille Vintage 0 Oct 22nd, 2007 7:18 am
Cleaning Frame/Engine Marks Nimi Sport Classic 6 Mar 29th, 2007 11:51 am
what cleaning producats are good for cleaning the front forks? ducati955 Ducati Motorcycle Chat 1 Feb 20th, 2006 3:57 pm
