Steering dampers Ohlins or Bitubo? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Dec 24th, 2011, 8:28 am   #1 (permalink)
I ride a Monster S2R. Looking to add dampers and I came across the Bitubos and thr Ohlins SD 153. The bitubos go on the handlebar and the Ohlins go on the fork. Any thoughts of the pros and cons of each damper. Thanks
2008 Monster S2R
Speedy Moto Sliders
MonsterS2R is offline   Reply With Quote
Old Dec 30th, 2011, 4:44 pm   #2 (permalink)
Either is a great option, both companies have been suppliers for Ducati for years... Matris also has good options to consider.
Bitubo has some really trick stuff, I just picked up an older style bitubo carbon cross-mounted damper... You may want to check out the Ohlin's damper kit that Arrow makes so you can mount the Ohlins damper above the handlebar (like bitubo)
Make sure you get the kit that is compatible so you dont have interference with your tank.
Designer2011 is offline   Reply With Quote
Old Dec 30th, 2011, 10:23 pm   #3 (permalink)
Be aware that a cross mount won't work if you have risers instaled.
I used the Ohlins side mount and quite like it.
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Dec 30th, 2011, 11:53 pm   #4 (permalink)
I've fitted a DP steering damper on my S4Rs which seems to work OK, one word of warning, be careful if you lift the tank as the damper is very close and could easily damage the paint.
mr shifter is online now   Reply With Quote
Bitubo steering dampers Sputniks StreetFighter 17 May 5th, 2011 7:49 pm
Bitubo Steering Dampers now available for the Hypermotard BellissiMoto BellissiMoto 11 Aug 7th, 2010 2:23 pm
WaspTMSD Bitubo dampers are in... wasp1000 Sport Classic 6 Sep 24th, 2009 1:22 pm
By popular demand... 848 Steering dampers from Bitubo now available! BellissiMoto BellissiMoto 0 Jun 9th, 2009 1:31 pm
Are the OHLINS STEERING DAMPERS much better than stock ones Cigarlvr Superbikes 23 Feb 6th, 2009 7:08 pm
