M1100 Evo DTC error? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Dec 18th, 2011, 1:55 am   #1 (permalink)
I was riding around today making 2 or 3stops, and turning off the bike each time, but when I fired up the bike the last time and went to take off.... over 10 mph the over rev/dtc light flashes and cuts power. Fortunately I was able to ride the shoulder into a parking lot. Tried a few more times to accelerate and same thing. Turned the bike off, sat for a second and turned bike back on, tested it a couple times in the parking lot with no problems and made it back home. Traction control is set at level 1. Bike has 2900 miles. 2nd time this has happened since ive owned the bike. Before I run it back to the dealer anyone else run into this?
rubbersidedown is offline   Reply With Quote
Old Dec 18th, 2011, 12:01 pm   #2 (permalink)
humblepie's Avatar
The same thing happened to me 3 times. The first time @ 500 miles then @ 1500 twice 5400 mile now has not happen since
humblepie is offline   Reply With Quote
Old Dec 18th, 2011, 7:17 pm   #3 (permalink)
Mine has never done that in 3000 miles, definitely have the dealer check it out, you may have a bad wheel speed sensor, or some sort of calibration/ecu issues. Since the ABS is tied to the same wheel speed sensors it could be affected as well. Just a thought....
2012 Monster 1100 Evo
Termignoni Carbon Exhaust with Race ECU and Air Filter
Evotech Exhaust Bracket
AFAM 14T Front Sprocket
Ducati Performance Fender Eliminator
Ducati Performance LED Turn Signals
SpeedyMoto Frame, Fork, and Swingarm Sliders
Vapor Canister Removal Mod
Rizoma Spy-R Mirrors with Rizoma Sportline Grips
Suspension tuned by Catalyst Reaction Tuning
alininger2001 is offline   Reply With Quote
Old Dec 22nd, 2011, 10:11 pm   #4 (permalink)
Exact same thing happened to me. I have a 2012 1100 EVO. Happened only once with about 500 miles on the bike. It just flashed the lights at the top of the dash and with any throttle input it would completely bog down and almost stall. I rolled to the side of the road turned it off. Waited a few minutes. Started back up and all was fine. Has not come back in the last 1000 miles. When I mentioned it to the dealer last time I was there (did not have the bike however) they sounded surprised and just shrugged it off as "Ducati character". Ugg.
I've had more crazy things with this bike in the 1400 miles I've owned it then all the bikes I've owned before combined (which isn't that many however). They probably couldn't design a noisier engine than this if they tried (aside from going back to a dry clutch). All sorts of strange clunks, clanks, chatter, and clicks. Maybe someone left a wrench in there during assembly... And I thought my Vulcan's EN500 was a noisy engine!!
jagibbs is offline   Reply With Quote
Old Dec 24th, 2011, 1:22 am   #5 (permalink)
The same thing happened to me on my very first M1100 demo ride. The bike had less than 150 miles on it. It suddenly would lose power and sputter over 10 mph. I hobbled back to the dealership and told the manager. He had never heard of such a thing and seemed concerned about it. He started it back up, rode it around and it worked fine. I took another test ride and it never happened again.
ducati_russ is offline   Reply With Quote
Old Mar 15th, 2012, 2:01 pm   #6 (permalink)
I took my bike to the dealer last week and they werent able to pull any codes or duplicate the issue with the dtc.... I did however get my front rotors replaced under warranty due to being warped
Old Apr 14th, 2012, 3:32 am   #7 (permalink)
watch this video which demonstrates the 1100 evo DTC problem
godudi is offline   Reply With Quote
Old Apr 14th, 2012, 5:24 pm   #8 (permalink)
Originally Posted by godudi View Post
Holy Now thats messed up.... We need a fix from Ducati ASAP.
2012 Monster 1100evo black/grey
Fireman1291 is offline   Reply With Quote
Old Apr 14th, 2012, 5:43 pm   #9 (permalink)
That's it right there!! Good to see some documentation of the issue hopefully one step closer to a cause/solution.... I watched my dealer hook up the scan tool and check for codes and everything was clear.....is that kph or mph?? Mine wouldnt go above 10 mph when it happened to my bike.3800 miles on the odo and hasn't happened since.
Old Apr 15th, 2012, 8:07 am   #10 (permalink)
Thanks for doing that. Mine wouldn't go above 40MPH after a stop at a traffic signal, but it only did that once, so far, on that one ride, about two months ago. Dealer said no codes showed up when they read it (they did this while replacing the recalled rear wheel). I had my DTC on Level 4 when it happened. I was, and am, guessing that it also was a DTC error, but I don't know how to tell for sure, since I can't duplicate it (hopefully it will never happen again). I assume that your DTC was on, since you note that it's a DTC error, but do you remember what Level it was on when it happened?
Thanks!
Mike in Annapolis, Maryland
ekiM is offline   Reply With Quote
Error code 37? Oldrider57 HyperMotard 9 Dec 28th, 2010 12:56 am
Help please- CEL & Error codes jryden HyperMotard 2 May 30th, 2010 10:35 am
Fan error help LaRossa StreetFighter 14 May 11th, 2010 8:13 pm
Error 2.1: Pick-up Pressure error fred2602 HyperMotard 13 Feb 17th, 2008 7:55 am
EF1 Error on dash lost1 Superbikes 19 Feb 12th, 2008 3:26 pm
