Dave, are you sure this map shows gain merely from adding a PC (upper curve) to the Termi/DP ECU set-up (lower curve)?
There is a 20 per cent increase here, which seems much more consistent with expectations for what Termi/DP ECU plus PC (upper curve) would give over all-stock (lower curve).
Very nice looking shape tho.
