2000 M750 starts choking after 30 minutes then won't start - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 13th, 2011, 4:39 pm   #1 (permalink)
Hello; I bought a 2000 M750 with 1700 miles a months ago. The guy I bought it from, owned for few months from the original owner and put 700 miles on it, with no problems, as he told me. He advertised it with all work done...etc.
The first problem I had was a month ago, it started hesitating and choking after riding it for 20 or so minutes and getting up to 4th gear/60 mph. It totally stopped then started at that time. I found out that a hose was pinched between the tank and the frame so I fixed that problem and though that was the end of it.
Today, after riding for 30 minutes and going up to 65-70 mph, it started acting up like the first time above. I managed to get it back to my garage. In 30 minutes or so, I started again and it was fine, so decided to take it for a quick spin and that is when it started hesitating again and totally died. Won't start no matter what.
I checked all the hoses and nothing is obstructed under the tank. I cleaned the small hole under the gas cap with compressed air and still no luck.
I then noticed two things which got me really concerned
1- The engine oil was very low in the side screen so I topped it off
2- Right under where the battery sits, there is a small finger tip size area which is almost corroding and collecting a black oily droplets which when I touch, comes down as a blackish oily drop on my finger tips !!
Any ideas what I may be dealing with here? I plan to take it to a mechanic shop tomorrow, but hope someone can shed some experiences/thoughts..etc
btw, the guy I got it from, told me he never had this problem with the choking bike !!!
Myocean4vr is offline   Reply With Quote
Old Nov 13th, 2011, 7:24 pm   #2 (permalink)
jackoduc's Avatar
Hi, I have a 2001 M750 (carbed) that I bought new in 01. When I first get it
I had a similar problem. The bike would just die after 30 min. and wouldn't restart for about 15 min. then run just fine. It acted like a "vaper lock" where the fuel gets to hot and boils. I finally figured out it was a "tip over"
valve in the fuel tank. The shop ripped out the tube and valve and it hasn't happened again for over 9 years. Next time it happens open the fuel tank and listen to see if you have a vacuum in the tank. Have you pulled the spark plugs to check for spark or wet foulling? Hope this helps. M750 is a very fun bike.
Jack
2001 M750 Red
2003 ST4s Senna Gray
jackoduc is offline   Reply With Quote
Bike won't start in the morning - takes 5 minutes elambo Monster 24 Jun 5th, 2011 6:46 pm
01 996 Starts up for a few minutes ok then looses power and stalls. M.Sias Superbikes 18 Oct 8th, 2010 12:39 pm
Using a 2001 tach on a 2000 M750... yosso Monster 0 Jun 4th, 2010 1:35 pm
Starts when I release start button Toro Supersport 3 Aug 14th, 2009 9:32 am
1994 M900 or 2000 M750 schnitzer325 Monster 3 Jul 12th, 2006 9:28 am
