Cam timing vs valve adjustment - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 9th, 2011, 9:56 am   #1 (permalink)
I have a few questions about cam timing:
If you are getting your valves adjusted, are the cams timed at the same time?
Have any of you got your cams timed & seen some HP gains on a monster? I heard Ducati specs are kinda loose.
What are the benefits of cam timing?
Thanks in advance!
Stradabling is offline   Reply With Quote
Old Nov 9th, 2011, 12:02 pm   #2 (permalink)
Bob92's Avatar
The two operations are separate. Valve adjustment is independent. Cam timing is a straightforward but lengthy process, and costs will vary quite a lot depending upon who does it and whether much needs to be done. Ducati build motors on a production line, and as far as I can tell, all production bikes get the same timing. On newer bikes, (Testastretta) they have gone to a tooling approach that takes a major chunk of the tolerance stack-up out of the build process and should result in fairly consistent timing. On the older bikes it was basically whatever the build process tolerances came up with, and relied upon keyways and woodruf keys. To adjust timing on either system requires several measurements to be made, followed by adjustment and re-measurement. Takes time, so costs will depend upon your shop rate.
You are what you practice to be.
'98 M750
'99 ST4
'00 748R (almost RS, track only)
'08 1098 (track only)
Bob92 is offline   Reply With Quote
Valves, Cam Timing & Suspension Adjustment Gilly StreetFighter 11 Aug 22nd, 2010 11:11 pm
Timing Belt Change and Adjustment 07ducati800ss Supersport 8 Aug 1st, 2010 6:01 pm
Timing Belt Adjustment ton_up Sport Classic 65 Aug 22nd, 2009 2:57 am
Timing adjustment inferno493 Supersport 7 Aug 11th, 2009 7:55 am
Cam timing and valve adjustment expertise sought Perfution Sport Touring 9 Oct 13th, 2007 11:17 am
