help...... rear brake cylinder won't work monster s2r 1000 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearMotorcycle.com
Old Nov 7th, 2011, 4:43 am   #1 (permalink)
hey i have a ducati monster s2r 1000 year 2006
and my rear brake wont work
-the brake fluid is good
-no air in the system
-nothing on the back pads when i try to brake
my question is .....
should i try to fix it or
better to buy an new one
if yes, where should i buy it from ?
or could i take one from an nother bike ?
thank you
s2rraphael is offline   Reply With Quote
Old Nov 7th, 2011, 6:57 am   #2 (permalink)
i'm sure it's rebuildable but this is how i'd go..........
s2r master cylinder | eBay
Mike in Tacoma
an analog man in a digital world
'08 S2r 1000
'02 ST4s (gone bye-bye)
IBA 38181
sofadriver is offline   Reply With Quote
Old Nov 7th, 2011, 7:21 am   #3 (permalink)
Lifetime Premium
Do you mean that your pedal goes full travel with no effect on the rear wheel? Or, is the pedal solid and you don't believe you have a strong braking action?
Rear brakes are typically not strong. Also, make sure you are using the correct fluid. Synthetic brake fluids can render the brakes pretty much worthless.
ST3S is offline   Reply With Quote
Old Nov 7th, 2011, 7:34 am   #4 (permalink)
DropLock's Avatar
thank you
So you're saying the fluid is clean?. Have you just bled the system? Sure it's the right DOT?
Nothing ON the pads?? What do you mean? _There's no pressure or no friction material left?
Fix it? - Depends on the problem
New - Ditto
DropLock is offline   Reply With Quote
Old Nov 9th, 2011, 12:08 am   #5 (permalink)
well the pedal goes full travel with no effect on the rear brake peads....
the thing is if i break in the stand or driving it feels like i hit in the nothing
MTS 1200 - Does your rear brake work or not? brust60 Multistrada 215 Oct 22nd, 2011 5:19 pm
Rear brake does not work red_johnny Supersport 14 May 30th, 2011 9:07 pm
Ducati 800 SS - Front Brake Cylinder/lever swap with 1000 SS? adalta Supersport 4 Jul 7th, 2006 10:12 pm
749 brake master cylinder rebuild? It doesn't feel right, and brake lights don't work rustysrustyduc Superbikes 5 Jun 7th, 2006 2:35 pm
will this monster brake lever work with a 98 CR? britcoal Supersport 1 Apr 11th, 2006 10:06 am
