Bubble Inside My Tank! - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 7th, 2011, 2:43 am   #1 (permalink)
Queestce's Avatar
G'day all,
Was swapping out a fuel filter today and came across this unusual suspect...
[img width=652 height=600]http://img545.imageshack.us/img545/2708/img2107small.jpg[/img]
Anyone seen anything similar? It seems kind of like a blister... Could only see that one in there, I just left it alone, but I wondered if anyone knew what might have caused this, or whether it might cause any issues? The bikes an 06 M620ie.
Would appreciate any advice!
Cheers,
Tk
"You live more in five minutes on a bike like this going flat out than some people live in their lifetime." Burt Munro
06' Monster 620 | Termi's, DP Intake & ECU
84' Honda CT-110 | Bone stock - Never say die!
94' Kawasaki EL-250 | Divorced
04' Honda CT-110 | Divorced
89' Honda VT-250 | Deceased
Queestce is offline   Reply With Quote
Old Nov 7th, 2011, 6:54 am   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Originally Posted by Queestce View Post
G'day all,
[/IMG]
Cheers,
Tk
Fixed it!
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Nov 8th, 2011, 3:04 am   #3 (permalink)
Queestce's Avatar
Cheers Va! Not sure how I managed to mess that up... Can't seen to edit my orig post...
Anyone got any ideas?? Expanding tank syndrome in its beginning stages perhaps??
Old Nov 8th, 2011, 7:57 am   #4 (permalink)
Bishamon's Avatar
It may be a flaw from the manufacturing process, unless it wasn't there before, in which case it's probably a result of the nylon absorbing water.
2007 Sport 1000 SE
2011 Monster 796
Bishamon is offline   Reply With Quote
Old Nov 14th, 2011, 6:52 am   #5 (permalink)
Queestce's Avatar
Hmm, well this is the first time I've ever seen inside it myself so not sure if it's a factory defect. Could be water I suppose, but how would the nylon absorb water inside the tank? I guess I'll keep an eye on it and see if more pop up. Might give the dealer a ring too and see what they say.
Cheers,
Tk
Old Nov 14th, 2011, 8:29 am   #6 (permalink)
Bishamon's Avatar
The problem with the nylon tanks and ethanol isn't the ethanol itself, but the water that is absorbed by the ethanol. The nylon then absorbs the water, and you end up with tank expansion/deformation and bubbles. PA6 nylon can absorb up to 10% of its weight in water, if I remember correctly.
2007 Sport 1000 SE
2011 Monster 796
Something is sliding around inside my gast tank 1kduc Supersport 2 Jun 7th, 2011 3:40 pm
Plastic Tank Bubble/Bulge arai_speed Ducati Motorcycle Chat 11 Mar 16th, 2009 1:49 am
Hoses inside tank? TrojanHorse Superbikes 5 Feb 19th, 2009 11:02 am
Sport Classic tank bubble tbone Sport Classic 1 Mar 25th, 2008 10:58 am
Resealing inside of gas tank.... my748 Superbikes 2 Feb 24th, 2008 6:13 pm
