Clutchless upshifting - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Oct 19th, 2011, 1:49 pm   #1 (permalink)
Do many people here do clutchless upshifting? I've been reading about it a little and my friend has been telling me to try it. I have an '09 M1100 dry clutch (he rides a Triumph). Is it any different on Ducati's or on dry clutches? Would it not be recommended for me for any reason? Thanks.
-Paul
swankdaddy7 is offline   Reply With Quote
Old Oct 19th, 2011, 2:14 pm   #2 (permalink)
Yuu
Unless you're racing where fractional seconds count there's no real benefit.
That being said, it's no different on a duc. Give it the beans, lightly pre-load your shifter lever, quickly get off and then back on the throttle and voila, you should now be one gear up.
Important notes are to have enough, but not too much load on the shifter lever and that brief change in throttle.
Too much pressure on the shifter will force a shift while things are under load, or might force an attempt at a shift that goes all to hell. It doesn't take much pressure on the lever at all.
The change in throttle takes some of the load off the system, allowing the gears to change.
Yuu is offline   Reply With Quote
Old Oct 19th, 2011, 2:33 pm   #3 (permalink)
no need to preload the shifter; in fact, if you do preload, even the slightest, this load will push the oil out from between the running parts increasing friction.
Accelerate, back off slightly and quickly, bang on the next gear, resume acceleration.
One benefit is less wear on the clutch plates.
jcns is offline   Reply With Quote
Old Oct 19th, 2011, 2:39 pm   #4 (permalink)
I do this when my left hand is tired.
07 R1
TERMIGNI is offline   Reply With Quote
Old Oct 19th, 2011, 6:04 pm   #5 (permalink)
It's not necessary on the street, but the street is a good place to practice it. Whenever I'm getting onto highways (when I can reliably be full throttle through several gears) I'll do it. Or at least try to do it ;-)
positivecarry is offline   Reply With Quote
Old Oct 19th, 2011, 9:37 pm   #6 (permalink)
Wink
you can use the clutch for upshifting, too?
Mike in Tacoma
an analog man in a digital world
'08 S2r 1000
'02 ST4s (gone bye-bye)
IBA 38181
sofadriver is offline   Reply With Quote
Old Oct 19th, 2011, 10:14 pm   #7 (permalink)
Extended Member
CAlexio's Avatar
I know right... what is normal to one person is crazy to another... for example... i try to back it in on most turns and put my knee down while giving a thumbs up when riding my Hyper... doesn't everyone?
Old Oct 20th, 2011, 1:10 am   #8 (permalink)
999s's Avatar
I usually only clutchless up shift when accelerating pretty hard, like getting on the freeway or some such silliness. Other than that, I use my clutch.
my $0.02
Have
Silver 2007 S2R1000(my baby)
Charcoal Gray 1999 900 Monster
Black 2005 S2R800
Titanium 2007 S4Rt
Had
Black 2004 999S (Traded for Hyper)
Yellow 2004 749s (traded in for S2R1000)
Yellow 1997 748s (sold)
Red 2008 Hypermotard 1100s (sold)
If ya want Cars Suck stickers, PM me with an address and I will send some.
I really have no idea what I'm doing.
999s is online now   Reply With Quote
Old Nov 7th, 2011, 9:18 pm   #9 (permalink)
Jellonailer's Avatar
Did it all the time on my S2R800, sometimes not on purpose, justs slipped in so easy it happened - a little pressure and let up on the throttle and you're there. No big deal and effortless.
[SIGPIC][SIGPIC]
2006 Monster S2R800, Black/Tangerine "Sold"
1999 748S Monoposto,Yellow "Sold"
2004 SS1000DS, Yellow
2003 Porsche 996TTX50
1994 Porsche 968 White
2006 SLK280
2009 Jaguar XF Supercharged
1961 Italian, brown eyes, size 2, 992cc
Jellonailer is offline   Reply With Quote
Old Feb 16th, 2012, 11:28 pm   #10 (permalink)
Booster's Avatar
"and quickly, bang on the next gear"
Banging, stomping, pushing really hard is bad for the shift linkage and shift forks which all equal an expensive trip to the duc-doc. Light preload and slight on/off the throttle. Better to practice at lower RPM's as the gears are not spinning as fast.
You can also down shift with this method as well, lower RPM's also make this easier and less jerky. A slipper clutch makes this a easier proposition.
Official AxlJak Clutch and Water Pump cover tester. Work Great!
Booster is offline   Reply With Quote
clutchless upshifting way too easy elliottw Superbikes 8 Sep 21st, 2009 4:02 pm
Upshifting without clutch??? Kernel_Panic Sport Touring 10 Aug 30th, 2007 1:42 pm
Clutchless upshifting bromike666 Ducati Motorcycle Chat 12 Jun 19th, 2007 6:39 pm
Clutchless shifting?? st2brooke Ducati Motorcycle Chat 15 Feb 17th, 2007 10:36 am
Clutchless shifting Lars Supersport 8 Aug 12th, 2006 8:05 pm
