HELP Dual Headlights oily build up?! - Ducati.ms - The Ultimate Ducati Forum
Old Oct 13th, 2011, 8:27 pm   #1 (permalink)
So recently after installing my dual headlights and using them for the last 100 miles. I've noticed an oily build up inside the lens?!
The first thing I attempt to do is check the seals and take the bulb out to let the housing dry (assuming it was condensation at the time) but little to my dismay the fog didn't disappear. It's some kind of oily build up. I actually had to use a mircofiber to clean out the housing and the inside of the lens. So far i've cleaned them twice but they keep clouding up inside!
The headlights also have two parking lights which pop into the housing, exposing rubber. Could the heat from the bulb be letting the gases out of the rubber? Do bulbs release gas? Has anyone had this same problem?
Any input or help would be appreciated, thanks!
These are the headlights:Monster Parts: Monster Dual Headlights
theletterthomas is offline   Reply With Quote
dual headlights or alternative on m1100 stabmaster Monster 2 Jul 24th, 2011 8:38 pm
Dual Headlights need new bulbs?? TheBobMan46 Monster 4 Oct 23rd, 2010 9:11 am
oily goo coming from engine bolts? j5th Sport Classic 10 May 28th, 2009 11:32 am
Dual Headlights Jakem696 Monster 3 Aug 20th, 2008 3:20 pm
One oily bike fraz Supersport 13 Jul 19th, 2006 2:59 pm
