strange bars problem on 696 - Ducati.ms - The Ultimate Ducati Forum
Old Oct 11th, 2011, 2:58 pm   #1 (permalink)
i was looking at my wife's lil monster the other day and noticed that the bars hit the gas tank on left side before they hit the stop (bad side bars picture) and do not hit the gas tank on the right side - they properly hit the stop first(good side bars picture).
i've measured the bars and they are properly set (same distance from end to fork on each side).
my wife did drop the bike on the left side recently at 0 mph and i had to pull out the little mesh psuedo vent. but i find it hard to believe that such a low energy drop could have caused damage to the stop.
bike rides fine...
i'd appreciate any suggestions or thoughts on what's going on.
strange bars problem on 696-bad-side-bars.jpg   strange bars problem on 696-good-side-bars.jpg
2011 1198sp
2011 multistrada 1200s
2009 696 (my wife's lil monster)
2006 bmw r1200gs (gone but not forgotten)
bartman314 is offline   Reply With Quote
Old Oct 11th, 2011, 3:05 pm   #2 (permalink)
I'm not familiar with newer monsters so I can only assume the steering stops are the same as the old ones. Could the bolt/adjuster have backed out a bit? The one underneath the headset? Happens on my bike every once in a great while.
Chad F
'07 S2R1000
thejazzoflife is offline   Reply With Quote
Old Oct 11th, 2011, 3:15 pm   #3 (permalink)
CrimsonCloak's Avatar
Two things...the controls could have rotated slightly fouling the fit into that mesh pocket. The bars shifted in their mounts, they are rubber mounted so you may want to loosen and retighten them. Most likely the first. Only a few degrees will cause an issue.
M1100
CrimsonCloak is offline   Reply With Quote
Old Oct 11th, 2011, 7:31 pm   #4 (permalink)
fixed... at least from a practical perspective.
after making some more measurements and inspection, i decided to adjust the left side stop. after 5 minutes with a wrench and allen wrench, bars don't hit tank.
thanks for the inputs!
2011 1198sp
Old Oct 11th, 2011, 7:57 pm   #5 (permalink)
Secret Squirrel's Avatar
Wait a minute not so fast. This part is important. Do you know if the bars would hit the tank before she dropped the bike? If they didn't then you could have another problem. If the bars did rotate back slightly in the clamp from the fall then the bars would be close to the tank on both sides as long as the bars didn't bend. Simply adjusting the steering stops is just a bandaid and possibly not fixing the real problem. The forks and triple tree could of been knocked out of alignment when the bike fell over. It doesn't take much force for this to happen. If the forks are crooked you will need to get the front wheel up in the air and loosen all the triple clamp bolts and loosen the front axle and realign the forks properly. In a more serious crash you would need to check to make sure that the forks aren't bent. In your case I don't think you need to worry about this.
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is online now   Reply With Quote
Old Oct 12th, 2011, 5:37 am   #6 (permalink)
good input.
thanks for the sanity check - you're right i should check alignment.
2011 1198sp
Old Oct 20th, 2011, 4:43 am   #7 (permalink)
les96's Avatar
The bars will be bent, the originals are made of chrome cheese.
My wife dropped her 696 at 5mph and bent the LH bar into the mesh tank panel.
Rizoma MA001B make a black replacement set that also make the bars a little bit higher and closer to the rider, much more comfortable.
Two many to list...then
2010 Monster 696
2010 Multistrada 1200
les96 is offline   Reply With Quote
strange running problem PedroHM HyperMotard 3 Oct 2nd, 2009 7:02 pm
Strange Problem pasir Sport Touring 9 Sep 23rd, 2008 6:57 am
strange valve problem ducaati Sport Touring 12 Aug 18th, 2008 1:02 am
really strange ignition problem DJMPowersports Superbikes 1 Oct 17th, 2007 11:03 pm
Strange stalling problem number9 Supersport 13 Jun 15th, 2007 12:35 pm
