M1100 EVO hopping to neutral while engine braking? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 3rd, 2011, 12:32 pm   #1 (permalink)
Hi,
my bike has a little but a some what embarrassing fault:
when I engine brake into a corner (usually on the track) the gearbox drops to neutral without any gear change or even a hint of clutch play or gear lever play.
It just does it. And it has to be a long, hard engine brake. Typically from speeds over 150 km/h and 4th gear to 2nd gear, hard braking and then into a corner with the engine brake.
Almost drove off a mountain in Slovenia this summer and after that a few close calls in a local racing circuit here in Finland.
Anyone else having this? My dealer has promised to look into it but I would like to know if someone has had the same problems and maybe could hint the reason?
gt78fin is offline   Reply With Quote
Old Oct 4th, 2011, 12:33 am   #2 (permalink)
My god, no, I haven't experienced anything like that in my 3500 miles on my 1100 EVO. The thought of the bike switching to neutral during engine breaking on the approach to a mountain corner makes my testicles want to hide.
If it ever happened to me, just once, I'd have that thing in a garage being looked at with a microscope.
Be careful, man!
Jaelum is offline   Reply With Quote
Check engine light on M1100 CoolBDPhenom03 Monster 6 Jan 11th, 2011 1:50 am
Front wheel hopping under extreme braking? JohnMH Superbikes 14 Nov 24th, 2009 3:52 pm
Will a slipper clutch reduce engine braking? Activator HyperMotard 20 Sep 21st, 2009 10:05 pm
Engine braking vs brake braking TomT Supersport 7 Jul 4th, 2009 9:55 am
Engine braking...exhaust poping - Question level7 Superbikes 13 Mar 19th, 2006 7:02 pm
