You should be able to run the chain you have on it now
Dependent on miles on the chain and sprockets
Run your numbers through gearingcommander.com
on a 14/41 a 100 102 104 106 108 link chain is optimum for wear
a 15/44 is equal to a 14/41
You may be happier with a 14/39 for average riding
Plus it is economical mod to simply change the front sprox
JC
Originally Posted by giantdefy
Does anyone know if a 14/41 sprocket setup on a M796 would require a new chain?
I currently have a 14T sprocket, but still think the gearing is too tall.
I still find the 6 th gear useless, unless Im riding above 90mph which is once in a blue moon.
