Amsoil 10W-40 or 20W-50? - Ducati.ms - The Ultimate Ducati Forum
View Poll Results: which Oil would you use in your Ducati?
Amsoil 10W-40 9 90.00%
Amsoil 20W-50 1 10.00%
Voters: 10. You may not vote on this poll
Old Sep 18th, 2011, 12:43 pm   #1 (permalink)
Nick_Knipp's Avatar
I'm having trouble picking one of the two. can yall help me out, theres loads of info to help choose.. Will be using Amsoil filter as well
20W-50 AMSOIL - SAE 20W-50 Synthetic Motorcycle Oil (MCV)
10W-40 AMSOIL - SAE 10W-40 Synthetic Motorcycle Oil (MCF)
I'm not saying supidity is a crime, but why not take the safety labels off everything and let the problem solve itself?
-Unknown
Nick_Knipp is offline   Reply With Quote
Old Sep 18th, 2011, 1:13 pm   #2 (permalink)
DuckMan's Avatar
For any Ducati under most conditions 10/40 is the best choice.
Mike
DuckMan is offline   Reply With Quote
Old Sep 18th, 2011, 4:18 pm   #3 (permalink)
galaxy's Avatar
Images: 27
For 99.844777639942231% of all conditions, 10W40 is what you want. NO reason what so ever to run 20W50 in that motor. The lighter oil provides superior cooling in ALL conditions, less parasitic drag from pumping a heavier oil means hp and fuel economy. There is no reason at all to run a 20W50.
Besides, look in the book and you'll find 10W40 is the recommended oil. You don't even need a heavier oil if you're doing track days and/or running the snot out of it.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Sep 18th, 2011, 9:13 pm   #4 (permalink)
Nick_Knipp's Avatar
I guess its 10W-40 then, Amsoil website did show 20W-50 for an 07 S2R1000 but I guess thats out. the viscosity is just higher than the 10W-40, I'll order 4 quarts of the right oil and a filter. then do the service on it, its gonna cost $65 but worth it
-Unknown
Old Mar 16th, 2012, 4:01 am   #5 (permalink)
metroplex's Avatar
FWIW, I did some research and the 02-07 Monsters state to use 10W-40 in the manual. The 08-up Monsters (and other Ducatis) state to use 15W-50. I didn't hear an explanation as to why it went to 15W-50 for 2008-up. The only major change to my 696's engine is the removal of the ball bearings for the camshafts, and it now relies on oil film for lubrication and as a bearing surface. This suggests I should use a 10W-40 because it travels up to the cams faster than a thicker 20W-50, but I'm not an engine expert.
There are not the droids you're looking for!!
metroplex is offline   Reply With Quote
Old Mar 19th, 2012, 9:18 pm   #6 (permalink)
giantdefy's Avatar
I have a 2012 M796. Manual recommends 15W-50.
2012 Ducati Monster 796
giantdefy is online now   Reply With Quote
Old Mar 20th, 2012, 10:41 am   #7 (permalink)
I'm using Motul 10w50 5100 semi in my carby SS, best of both worlds!
Not happy at running a thick 20w50, 10w40 wont give you a good hi-temp protection - 10w50 it is.
Old Mar 20th, 2012, 10:48 am   #8 (permalink)
metroplex's Avatar
The Aprilia RSV4 specifies 15W-50 in the manual (Agip Tec 4T 15W-50). Amsoil recommends 20W-50 MCV for the RSV4 and Buell 1125R - both bikes can rev as high or higher than the Ducati engines.
AMSOIL filters, got one for nearly all your needs. Amsoil Dealer Group Amsoil Dealer Group 2 Apr 14th, 2012 3:19 pm
Putting Amsoil in my 748.... Gpprerunner Superbikes 8 Feb 23rd, 2009 7:45 pm
Amsoil @ MotoWheels!!! galaxy Ducati Motorcycle Chat 0 Jul 6th, 2008 10:41 pm
Amsoil: How many of you are using it? oalvarez Superbikes 21 Mar 25th, 2008 11:34 am
