so, not quite as easy as it sounds. On another forum it was mentioned that the coil mount is different but not a big deal...But, the rearset/muffler hangers are also different. I had to cut both mounts off the old frame. Weld them to the new frame in the correct location, cut the old mounts off the frame. Cut the old coil mount off new frame, weld new coil mount to the frame.
Not so bad as I am halfway competent welder but the hard part was getting the frame smooth where the old mounts were removed. I spent a LONG time grinding and sanding to make it smooth.
either way it off to powdercoat now. Turning a silver framed yellow bike in to a red framed black bike
