'97 Monster rear shock specs? Cross-references?
Well, it looks like 50k and Hyundai-induced wreck put the screws to my rear shock. I have a spare shock from Supersport of similar vintage, but I understand they're longer and might lift the ass end a lot higher than I want. (Not that I won't find out for myself, but in the meantime ... )
So I'm trying to find the specs on the rear shock to my '97 m750 (Sachs unit). Eye-to-eye length, spring rate, torque specs, alternate replacement options - hell, I'd be happy with just about anything. All I know is it's a Sachs w/ a yellow spring and it done broke. It's a good excuse to go hook up a nice Penske or Race-tech, but if I can do it cheaper (Ohlins ... $1100 ouch) that's fine too.
Even a means to cross reference the Ducati part number (365.20.18.1a) to some alternate aftermarket stuff would be greatly appreciated. Thanks in advance!
Just because you're not dead doesn't necessarily mean you're living. 1988 Paso 750 º 1997 Monster 750
Twist. Shift. Repeat as necessary.
