my concern about the low beam is the headlight turns on when the key is turned on, then the starter interupts power to the ballast until the engine starts which can short out the ballast and damage the bulb. High beam was the next logical step because I can control the on/off, but the flash to pass would be comprimised as the bulb takes time to power up.
