Ignition pick-up questions - Ducati.ms - The Ultimate Ducati Forum
Old Aug 4th, 2011, 5:06 pm   #1 (permalink)
Hello
I swapped my ignition pickups with two new ones from ktm. I also got rid of the cables, from the pickups to the cdi units, because there were a mess. I tried the service manual but the wiring diagram doesn't state which pickup goes to which cylinder. I remember that the upper left (9 oclock) pickup goes to the cdi of the horizontal cylinder and the pickup at the bottom right (5 oclock) goes to the vertical cylinder, is that correct? I would also like to know if any of you has used ktm pickups where the green cable goes (which pin) near the other 3 pin socket under the cdi unit or at the pin away from the 3 pins.
Thanks in advanced
PS The motor is 750cc 2 valve from monster 93-97. Its actually a cagiva elefant 750, same motor and spare parts
offroadtwin is offline   Reply With Quote
Monster ignition pick up conversion question dunlop0_1 Monster 1 Mar 16th, 2010 6:19 pm
Ignition pick-ups canterburyman Vintage 2 Dec 7th, 2009 1:04 pm
HELP me to pick one bowieshum Ducati Motorcycle Chat 35 Oct 15th, 2007 11:14 am
"Ignition Pick-up thingy-ma-jig..." desmofetish Superbikes 1 Feb 16th, 2007 8:53 pm
Ohms and Multimeter testing ignition coils questions Desmo Soundtrack Superbikes 4 Oct 9th, 2006 12:36 pm
