Aug 3rd, 2011, 5:38 pm
Tank spreading in Texas!
Mike
Aug 3rd, 2011, 6:31 pm
Check your air pressure!!!
That truly sucks, that bike of yours is beautiful!
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Aug 3rd, 2011, 6:36 pm
Well, maybe they are like women. Now there's just a little more of her to love.
Mike
Aug 3rd, 2011, 9:29 pm
Get your local Duc dealer to replace it under warranty asap as I think Ducati will only replace warped/expanded plastic tanks with a five-year limit. I had my '07 S4RS tank replaced twice and had it Caswell coated after the second replacement, apparently that's the fix to the issue. Basically, it's a barrier between the ethanol gas and the tank. At 6 months, so far so good ...
Aug 3rd, 2011, 9:32 pm
Lifetime Premium
Al Gore invented Global Warming, so I would start with him and then get your new tank coated before install.
Current bikes:
• '07 GT1000
• '68 Triumph Tiger TR6R
Past bikes:
• '70 Honda CB750 KO
• '65 Triumph Bonneville
• '62 Petro Mini bike
Aug 4th, 2011, 6:48 am
bite me
the tank on my first monster grew a little. i had to move the mounting/tilt bracket back as far as it would go.....in fact farther, i lengthend the slots in the mount with a dremel tool. it stabilized and didn't grow any more in the last couple of years i owned it.
my current monster tank has grown a little less than the first one, i'm keeping an eye on it. i did the same thing with the mounting bracket on this one, and always top off with gas on the way home......don't know if it helps but makes me feel better.
i can live with it as long as it doesn't bulge, or crack the paint.
both bikes are '07's (current bike was manufactured march 2006)
Casey
'07 Monster S4RS black
'10 Multistrada 1200 red
'12 Monster 696 ABS red
Aug 4th, 2011, 8:03 am
Yea, it doesn't look bad. I just noticed it hitting the top triple clamp. Now that I look a little closer it also now hits my steering damper when I try to lift it. The frame support rubbers were also not in the right position either but I was able to adjust them a little. I already had the mount all the way back but may try elongating the holes too. This is my second tank which I replaced at my own expense so I know how EXPENSIVE these suckers are. My first tank had an accident when it was petty new.
Mike
Aug 4th, 2011, 9:27 am
Motovation Accessories
Sucks to hear....with all this heat we are getting, im surprised they dont just spontaneously combust!
Aug 5th, 2011, 3:08 am
Last year, the rubber bumper under the right side of my S2R1k tank was half way on its way to the outside of the frame. This caused the tank not to sit level, changes the tension on the center lock lever thingy and since the tank was also pushing forward, it made locking the tank impossible since there was no room to lift the lever. It was replaced last year as well as the tank on the StreetFighter. Hope you get it fixed without any issue$.
Aug 5th, 2011, 11:17 am
Hello
How does one obtain this magical Caswell coating?
Can it be self-applied?
TIA,
guido in Houston
'03 sT4s ABS (sport TOUR)
'02 St4s (SPORT tour) w/ MBP Testarosso heads, DucShop Crank w/ Carrillo Rods, Pistal Pistons
'05 S4R - Work in Progress
'07 S4RS - Work in Progress
'03 ST4S-RS Moving past conceptualization......
'80 BMW R1050S Hybrid Cafe (gotta get back together soon...)
"It ain't really "yours" until you've MODIFIED it!"
