Originally Posted by Shazmak
Moronic, I should also just say that the printed owners manual that came with the bike has 1.5 turns +/- 1.4 turns for both 1100 and 1100S on the forks. Looks like an error because the pdf you linked has turns for the 1100 and clicks for 1100S. I should have suspected as much since it didn't make sense and I've spotted a couple of other mistakes in the manual - apparently my bike has a wet clutch and compression adjustment on the rear shock!! (it has neither)
Bloody hell, their manuals must be getting worse, not better. No wonder you were confused.
I'v not read or heard much about the Ohlins kit on the M1100, nor have I tried out that model. I'm surprised tho if you are finding the fork action harsh. Your first move could be to check that the fork clickers are indeed at stock settings.
If the forks have been apart at all - to replace fork seals for example - then it is possible someone has put overweight oil in there, or too much of it.
I found the stock setting on my S4Rs Ohlns fork nicely compliant.
The rear end is a different question. My S4Rs Ohlins shock was appallingly harsh. I'm always surprised not to read more about this from others. I have also seen the odd comment about the M1100s shock kicking a bit over bumps, which I find remarkable since it is only an emulsion design
AFAIK, so you'd think they would not want to work it hard on the compression side.
You are likely right about stock preload being good for your weight (assuming your settings are indeed stock). I suggest you try softening the rebound damping adjuster as far as it will go.
If the shock is still harsh, and the spring setup is close, then your only option is to go for a revalve. I had mine done by Cogent Dynamics in the 'States, with great results (report
here), but I also spoke to a salesman at suspension shop Teknik (link
here) at Penrith, who was well across the common need to cut back on Ohlins compression damping. I went with Cogent mainly because by then I'd convinced Rick, the owner, that I knew what I wanted.
Ohlins suspended Ducs deserve to work great. And possibly the best part of having Ohlins gear is that you can fool with it until it does work - provided you can find someone to help. Good luck!
