796 torque specs please - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Jul 21st, 2011, 9:13 am   #1 (permalink)
mojodog's Avatar
Anybody have the following specs? front axle, axle pinch bolts, front caliper bolts, and right side rear axle. Time for new tires. Thanks.
mojodog is offline   Reply With Quote
Old Jul 24th, 2011, 5:57 pm   #2 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Here is what I have from LT's manual, maybe someone on here can verify this information for you.
According to LT's manual:
Front axle 63nm-46lb ft
Pinch Bolts 20nm-15lb ft
Caliper bolts 43nm-32lb ft
Right rear side 176nm-130lbs ft
I would look into buying a service manual if you plan on doing any further work to that bike.
Cheers!
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Old Jul 25th, 2011, 6:50 am   #3 (permalink)
mojodog's Avatar
Not going to happen. I've dropped hundreds on manuals over the years and would rather just spend the money on tires. My service manager will give me the numbers but I have to go in person. I was just trying to save time since I do my own changes. Thanks again.
Old Aug 15th, 2011, 4:06 pm   #4 (permalink)
evl_twn's Avatar
Anyone know if these are the same torque specs used on the M1100/M1100S?
What's the best source for the service manual? I can't believe they don't give you even the most basic torque specs in the owner's manual.
Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... - Hunter S. Thompson
evl_twn is offline   Reply With Quote
Old Aug 15th, 2011, 5:02 pm   #5 (permalink)
evl_twn's Avatar
Also looking for the torque specs for the rear hub pinch bolts (chain adjustment).
Thanks!
Old Aug 16th, 2011, 11:19 am   #6 (permalink)
mojodog's Avatar
I squeaked these from a very helpful service manager
front wheel nut 63nm grease
rh rear axle 176nm grease
front brake caliper initial 2nm grease
then 45nm grease
front axle pinch bolts 18nm grease 1-2-1 sequence
don't forget to align your forks
adjuster pinch bolts 31-34nm grease 1-2-1 sequence
Nut torque specs- Dodd HyperMotard 2 Jun 26th, 2009 10:25 am
torque specs superhawk Superbikes 1 Mar 13th, 2009 10:28 am
torque specs my748 Superbikes 2 Mar 30th, 2007 7:41 pm
Torque Specs curveman99 Supersport 8 Feb 3rd, 2007 8:51 am
Torque Specs dbd Sport Touring 3 Feb 2nd, 2007 10:39 pm
