BIMOTA DB7 Marzocchi Corsa RAC front forks ???
For those of you who own or have ridden the BIMOTA DB7, I was wanting to know how well the Marzocchi front forks work/perform???
Are they comparable to R&T Ohlins? How do the compare to the Paioli WSB forks like those on the BIMOTA SB8R/SB8RS bikes???
If I understand it correctly, the DB7 front forks are the Marzocchi Corsa RAC 43mm forks. Marzocchi also makes a 50mm Corsa RAC forl too....I wonder why BIMOTA went with the 43mm forks instead of the larger stiffer 50mm ones?
Any feedback is appreciated.
thank you
