DB2 engine problems - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Feb 1st, 2010, 3:25 am   #1 (permalink)
DB2 engine problems
Does anybody know if the DB2 has the same engine problems as the 900SS from that era ?
crack in carter, valve guides and some other things but I can not really recall at the moment.
I am looking at a DB2 that is for sale but the engine is not starting and the bike is for sale in an auction lot about 800 Km's from my place so I can not go over to take a quick look (damn you speed limits).
It is possible the engine is not starting because of a dead battery. They don't really check the bikes thoroughly.
There are about 9000 km on the speedometer so I think there is a big chance that the engine is still ok.
any comments ?
On the other hand maybe this bike will sell cheaply and I can go hunt for a spare 900 SS engine to replace it.
anatak is offline   Reply With Quote
Old Feb 1st, 2010, 8:04 am   #2 (permalink)
dnovo's Avatar
The DB2 (and the DB3 and DB4 other than the DB4ie) used an unmodified, stock Ducati 900SS engine. There should be no differences between the one in the DB2 you are contemplating buying and any other 900SS of the same vintage. Parts remain plentiful and it is a relatively easy engine to work on. Dave
Time Wounds All Heels
dnovo is offline   Reply With Quote
Old Feb 1st, 2010, 2:53 pm   #3 (permalink)
Carbs were lightly modified to match Bimota exhaust and gave a much smoother response than stock 900SS, cylinder head bolts have been known to break but there is a later (stainless?) version that solves that problem relatively cheaply. If its been sitting for a while the battery is the first place to look.
quadrasuarass is offline   Reply With Quote
Old Feb 1st, 2010, 4:49 pm   #4 (permalink)
Thank you
Thanks everybody for the responses.
to quadrasuarass
do you know a source for the stainless cylinder head bolts ?
Old Feb 1st, 2010, 5:07 pm   #5 (permalink)
Muschi's Avatar
i think the later generation of SS900 cylinder studs weren't stainless,
but slighty increased in diameter, from 7.6 to 8mm, starting in 1993
with engine number 013833. Older studs are silver, the later ones
are black. They can be purchased at any ducati dealer, there are
some nice aftermarket studs available also, at places like california
cycle works in example.
cheers.
guzzi please, with 18" and tonti frame.
Muschi is offline   Reply With Quote
Old Feb 1st, 2010, 5:23 pm   #6 (permalink)
The local Ducati dealer did the fix for me, I don't have the bike anymore and it was a while back so I'm a bit vague on the exact details, the other Muschi response seems to cover all aspects of this issue.
to quadrasuarass
Lightweight Flywheel - Pros and Cons Shazaam Hall of Wisdom 30 Dec 13th, 2010 9:24 am
Engine Break-In Procedure - New vs. Rebuild Shazaam Hall of Wisdom 5 May 28th, 2010 12:15 pm
I added the wrong FUEL!!! beestiboy Ducati Motorcycle Chat 86 Jan 18th, 2010 1:27 am
748 engine parts 2 phase 1999 year Great deals!! krazy1 Parts and Accessories 2 Jan 5th, 2010 7:35 pm
Potential engine problems w/ slip-ons as opposed to a half-system on 999? kabinski Superbikes 1 Jan 22nd, 2006 2:33 pm
