Bimota unveiled the DB8 as a "cheaper" entry level bike. No carbon fiber, lower spec suspension, but way more power with the 1198 engine.
Is it worth the 35k price if you can get the DB7 for a few grand more?
http://www.madisonsportbikes.com/201...osto-sportbike
BIMOTA DB8 ENGINE SPECS
Source: Ducati 1198 Testastretta Evoluzione, 4V 90°Twin-Cylinder
Displacement: 1198.4 cc
Cooling System: Liquid Cooled
Compression Ratio: 12.7±0.5:1
Maximum Power: 170 HP @ 9750 rpm
Maximum Torque: 96.9lbs•ft*@ 8000 rpm
Exhaust System: 2-1-1, stainless steel
BIMOTA DB8 CHASSIS SPECS
Frame: Welded 39NiCrMo4 Tubing and Machined 6082 Aluminium Alloy Plates
Wheelbase: 1435 mm
Front Suspension: Marzocchi USD forks DLC fully adjustable
Rear Suspension: Extreme Tech Monoshock fully adjustable
Fuel Tank: 4.23 gallons (1.05 gallon reserve)
Total Weight: 178kg (392lbs)
Steering Angle: 25°
Seat Height: 800 mm
Overall Length: 2100 mm
Overall Width: 700 mm
Overall Height: 1115 mm
Ground clearance: 135 mm
Front Brake: Double 320mm Brembo floating disc, 4-pistons radial Brembo callipers, radial pumps
Rear brake: 220mm floating disc, 2-piston Brembo calliper
Front Tire: 120/70 ZR 17 Dunlop Sportmax GP Racer
Rear Tire: 190/55 ZR 17 Dunlop Sportmax GP Racer
