bimota 10 miles kept in living room! - Ducati.ms - The Ultimate Ducati Forum
Old Sep 23rd, 2009, 11:55 am   #1 (permalink)
mario65's Avatar
I found a bimota db4 with 10 miles kept in a living room. What's it worth to buy and what's retail? what should i look out for?
2011 DUCATI DIAVEL Termis, Bazzaz, Carbon overload
2003 DUCATI ST4S DP
2004 999r FILA #104. Sold to the Aussie moto museum
1994 M900 Monster PCS turbo (1st documented Turbo DUC) Sold to the Aussie moto museum
2003 DUCATI 749 yellow stock 4k mls (sold)
2004 DUCATI MULTI moto corse (sold)
2005 MV F4 blue (sold)
mario65 is offline   Reply With Quote
Old Sep 23rd, 2009, 8:42 pm   #2 (permalink)
mario65's Avatar
Its a tricolore mono non FI, perfect original.
Anyone?
2003 DUCATI ST4S DP
Old Sep 23rd, 2009, 11:45 pm   #3 (permalink)
Administrator
scott's Avatar
Images: 2
Sadly this forum is very quiet but I would think it is worth at least $8K
Scott
Sacramento CA
HDDC Posse
'05 BMW LT-C Ocean Blue
'03 Ducati ST4S with ABS
'08 BMW F800ST (Jessica's)
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scott is offline   Reply With Quote
Old Sep 23rd, 2009, 11:59 pm   #4 (permalink)
Uzziah's Avatar
I've heard of a garage queen and a trailer queen...
This is the first time I've heard of a living-room queen, though.
Are you thinking of buying it as an investment, basically to just look at? There are far uglier things I've seen displayed in people's homes. That would probably make it worth more than a bike that's been used and you just want to ride it.
Depending on how long it's been parked, if you intend on riding it, you should have it checked out. The tires should probably be replaced, but beyond that seals and gaskets can dry out and shrink as well.
If you pick it up, share some pics!
Uzziah is offline   Reply With Quote
Old Sep 24th, 2009, 9:34 am   #5 (permalink)
Bruce_Allison's Avatar
Personally I'd avoid it (unless you want it for display purposes).
Here's what I'd be worried about>
Rust in the cylinder walls/valve seats/rings...even the trans gears, etc.
Timing belts
Brake seals in masters & calipers...and clutch slave too.
ALL hoses> water, brake, oil, fuel
Tires
What's it worth?...probably $9-$11k if it was ridable...which it isn't right now without a lot of parts & work.
Bruce
Bimota Bruce
1995 916
2002 748s
Tre Bimotas
Bruce_Allison is offline   Reply With Quote
Old Sep 24th, 2009, 10:45 pm   #6 (permalink)
mario65's Avatar
I appreciate the responses. It has been started and run regularly just up and down the street.
thanks
2003 DUCATI ST4S DP
Old Sep 24th, 2009, 10:55 pm   #7 (permalink)
Catimann's Avatar
I agree with Bruce but don't think you should avoid it. You need to ask yourself this question; Is it worth the gamble? ALL the things Bruce listed can be wrong or could go wrong in the next little while. The safety items like tires, brake lines etc. NEED to be replaced and can be bargined over.
There is one on Ebay now that did not sell for $7900 last time round and is relisted: http://cgi.ebay.com/ebaymotors/ws/eB...3D10%26ps%3D63 It could have similar problems for the low mi it has and it has other issues.
For that matter you can bargin over all of the stuff because it is all unknown. I know a mechanic who picks up all sorts of old vehicles and puts them back on the road. Some after years of sitting outside and some have issues and some do not. Fix up what is NEEDED and ride it but I would not take a cross country tour until you have a year or 5000 trouble free miles on it. (What I would do to see if the motor will be ok.)
I bought an old Moto Guzzi for my wife with less than 8000 miles on it. It had sat for over 10 years and needed $1200 worth of rubber replaced. The MG engine has an oil pan that comes off so you can see the crank, and cyl's from below. I used a small LED light to see inside from the top and it was like new. I rebuilt all the brakes, and more to get it up to snuff. The same goes for the DB4. If it really sat in a living room for all that time take a good look inside with a light like this one: http://www.diytrade.com/china/4/prod...ake_light.html
Phone a Ducati dealer and ask how much it would cost to do a rebuild on that motor.
Good luck.
Andreas
93 DB2, 74 MG 850 Eldorado police, 93 KLR 250, 06 DRZ400SM
Catimann is offline   Reply With Quote
Old Sep 25th, 2009, 1:08 pm   #8 (permalink)
Talking
I woke up this morning and said to myself "Did I recommend changing the WATER HOSES on a DB4 to a guy the other day?!?"
DOH!!
Bimota Bruce
1995 916
2002 748s
Tre Bimotas
Old Sep 28th, 2009, 9:26 pm   #9 (permalink)
Catimann's Avatar
thanks
You were typing this as I was doing mine so I did not know this. I'd say it is very much worth looking at in this case.
Andreas
Andreas
3 days in the life of a duck JimC Ride Tales 4 Sep 7th, 2007 5:50 am
Living room ornaments grendels_arm Superbikes 0 Jan 2nd, 2007 11:39 pm
Ducati in the living room igor Superbikes 8 Nov 28th, 2006 2:12 pm
Bike displaced from family room!!! LYuan Superbikes 44 Nov 22nd, 2006 2:02 pm
One piece track suit: My Fitting Room Nightmare migz123 Ducati Motorcycle Chat 19 Jul 13th, 2006 3:07 pm
