Hello guys,
I just picked up a a DB3 that needs a little TLC.
The worst thing is that the Previous Owner stripped the threads that the axle screws into
!! and Simply cut off the end and put a nut on it! So the adjust twists and self destructs under load. Took me about and hour to get it loose..
It looks easy enough to make...but before i do, anyone have a source for this part?
Left side rear wheel adjuster.
Importer says no...and if you need anything else..
thanks
Dale Orto
