A few DB4 questions?
1) For you that have put radial clutch masters on, what did you do about the choke lever? Currently it is mounted on the clutch master, but the radials don't have the mounting tabs for a choke lever.
2) How much slack are you running on the Chain with the bike? On the kickstand or a rear center stand? No info in the manual, and there is only a caution sticker on the chain guard.
3) There are no rear wheel alignment marks when adjusting the chain? I guess I will use a string from the swingarm pivot to the rear axle. Anybody tried the lazer alignment tool? or any thing else.
Thanks
2002 Cannondale E440 Enduro
2003 Cannondale E440 SuperSingle project
2003 Cannondale E440 motard
2000 Bimota DB4ie BiPosta
