Antera wheels - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsCycle GearMotorcycle.com Classifieds!Honda Powersports
Motorcycle.com
Old Nov 13th, 2007, 6:01 pm   #1 (permalink)
ZAWA's Avatar
Antera wheels
Just weighed the stock Antera wheels off the SB8RS, and added some other wheel weights for a comparison.
FRONTS
Antera 13.6lbs.
Duc 3 spoke 11.5lbs.
Duc 5 spoke 9.5lbs.
OZ alu. 8lbs.
BST 6.1lbs.
Dymag carbon 5.6lbs.
REARS with sprocket and carrier
Antera 19.10lbs.
Duc. 3 spoke 17lbs.?
BST 11lbs.
Dymag 10.4lbs
Helps to explain the 415lbs. weight of my SB8RS with the same amount of gas as the 1098. Of course there are some other tricks done to it.
Oh bye the way have the Dymags.
ZAWA is offline   Reply With Quote
Old Nov 15th, 2007, 9:02 am   #2 (permalink)
dnovo's Avatar
Interesting note. The overall weight issue isn't as much concern to me as the effect of the weight of the wheels on handling. The Dymags seem interesting Any idea how they will hold up in street riding conditions, i.e potholes, frost heaves, etc? Dave
Time Wounds All Heels
dnovo is offline   Reply With Quote
Old Nov 15th, 2007, 2:01 pm   #3 (permalink)
ZAWA's Avatar
I really do not see any problems with strength, remember they are replacing cast Alu. The thickness of the actual rim is about like a forged Alu. rim. So they have the strength as if built of steel and parabley much stronger then that. If you have worries about failure think what your butt is sitting on, on some of your bikes. They have made the bike handle much better, it feels a lot smaller also helped the weight transfer issue. It took a few more tricks to solve that issue, but got it done, it does not spin the tire as before when getting on the gas.
Old Nov 16th, 2007, 1:37 am   #4 (permalink)
Speaking of wheels, do you know where I still might be able to find wheels that fit the SB6? Don't need carbon items, just good old alloy ones will be fine.
froryde is offline   Reply With Quote
Old Nov 16th, 2007, 8:59 am   #5 (permalink)
ZAWA's Avatar
Froryde, My have a set of Antera,s off my YB11. Just got a new milling machine and lathe hope to make something lighter that will work on it.
Old Jan 16th, 2008, 11:06 pm   #6 (permalink)
Ducatierv's Avatar
The forks are also heavy. We weighed the YB11's against the GSXR750 at Traxxion and it was nearly twice the weight.
Ducatierv is online now   Reply With Quote
Old Jan 17th, 2008, 8:36 am   #7 (permalink)
ZAWA's Avatar
Did not think they were real heavey when working on the forks, thought they were light for how massive they are. Just finished making a set of Dymag seven spoke forged mag wheels work on the YB11. Had to make a few spacers and move the rear brake caliper. They really changed the bike, it feels like a 125GP bike, you think it turns. I think it is the best modification that I have ever done to a bike. I rode about 500 miles on it last week looking for turns, and looking for turns is what you do in Fl.
Old Jan 26th, 2008, 10:31 am   #8 (permalink)
Ducatierv's Avatar
Zawa, did the upgrade eliminate mid turn oscillation? All my YB11s and SB6Rs suffered with this mind you Hi Sports didn't help things either.
Old Jan 28th, 2008, 10:51 am   #9 (permalink)
ZAWA's Avatar
The frist thing I did to the YB11 was to make the front fork springs 10% stiffer. Then ran the sag at 15-25mm this seemed to help alot with the weaveing. When I weighed the Antera wheels and saw their weight, a light went off in my head. I think a leading axle fork is a self righting design, in that the fork wants to center it's self all the time. The heavy wheel just exaggerated the motion. The lightier wheels made the bike feel like a new 600. Also the standing up under hard braking while leaned over seems to be a thing of the past. As for the SB6, lightier wheels will help I would make sure you have the right sag and spring rate for you and your bike first.
Old Sep 23rd, 2008, 3:09 pm   #10 (permalink)
Ducatierv's Avatar
Zawa what suggestion on wheels can you provide to upgrade my YB11? The mid corner oscillation is so bad that I now don't bother taking it out.
it's Friday, let's talk Lightweight Wheels :) DogTown749S Superbikes 33 Jun 27th, 2007 10:56 am
wheels wheels wheels redbike Supersport 3 Feb 22nd, 2007 7:13 pm
OZ Racing/Bucci wheels for Ducati moto Motowheels 2 Nov 5th, 2006 12:54 pm
Bucci Forged aluminum wheels: double sided swingarm moto Motowheels 0 Aug 19th, 2006 2:21 pm
When buying extra wheels grendels_arm Ducati Motorcycle Chat 10 Jan 27th, 2006 9:17 pm
Search Engine Friendly URLs by vBSEO 3.3.2
Kawasaki Forum Ducati Forum Harley Davidson Yamaha R1 BMW S1000RR Forum
Vulcan Forums Ducati Monster V-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley Forum YZF-R6 Forum Sportbike Forum
Kawasaki ZX-10R Honda 1000RR Suzuki SV Yamaha FZ8 Can Am Spyder
Kawasaki KLR 650 Honda RC51 Suzuki V-Strom Star Motorcycles Aprilia Forum
Kawasaki Versys Honda Fury Suzuki GSXR Triumph Forum KTM Forum
Kawasaki EX-500 Honda Goldwing GSX-R Forum Triumph 675 Victory Forums
