Make sure chain is loose
Take off sprocket cover
Disconnect the shifter from motor
If you can take off muffler this my be enough, just keep checking as motor is tilted.
All connectors, just keep checking as you lower motor for things that have to be disconnected our moved.
Go slow, it is not hard just slow in learning all the little tricks of your bike.
I have done it both ways on the DB2 it is much easier this way.
You do leave the swingarm bolt in place, the motor pivots on it.
