Perhaps I'm spoiled by single-sided swingarms.....
Anyway I was fussing with installing the rear DB7 wheel tonight,
and the clearances are quite tight making the job seamingly impossible.
Of course the owners manual says; "Pull axle - remove wheel... Reverse to replace" Thanks.
Well, if you remove the left side chain adjuster, there is just enough clearance to make removal and especially installation a lot easier.
After everthing is lined up, you just wind the adjuster back in past the spacer.
Good excuse to remove, clean, and admire some bits too.
