Oct 10th, 2011, 8:03 am
SB8 / YB11 Axle specs
Hi,
Could some one please mesure their front axle for me? You don not have to remove it just mesure the diamiter of the left and right side and mesure the width...
Thanks,
Gray
Oct 17th, 2011, 8:24 am
SB8 and YB11 the axle through the bearings is 25mm, the thick end seems to be 29mm on both, battery dead on the caliper so old school reading. The Thick ends are different though. Hope this helps.
Oct 18th, 2011, 9:42 am
Hi
Thanks alot for the info... can you tell me how long the axle is?
Thanks
Gray
Oct 19th, 2011, 9:01 am
The frork centers on both bikes are the same, the wheels and rotors are the same. The YB11 axle is about 8-10mm longer because it is not flush with the fork the SB8R is. I think they would interchange with each other. Let me know what you are trying to do maybe I could be more of a help.
Oct 19th, 2011, 12:11 pm
Hi,
I have a set of forks from a DB7 (marzocchi RAC43) That I picked up that are new. I want to use them on my 750ss they bolt up perfectly in the clamps and I was told they used a 30-25 axle. I found out otherwise when my 30-25 (999) axle would not fit. I found a sb8/yb11 axle on ebay for 25 Euros and wanted to know if it would fit. The DB7 axle will fit but is too long and will need to be modified... The sb8 looks like it is a bit long and will also need to be shortened as it is only 25 and not 150 Euros this seems like the direction to go for me.
The 999/748-998 axle cannot be turned down because the axle is only 2.35mm thick turing it down to 1.8mm is a little too thin for me.
Thanks for the info
Gray
Oct 20th, 2011, 2:20 pm
The 999 and 998 axles are different. I don't know how, but there are different part numbers.
Axles, Titanium for Motorcycles
From what I can tell, the 999 axle fits a RAC 50 and the 998 axle fits the RAC 43.
Marzocchi RAC works forks now in stock with pics!
Chris
1996 SB6
Oct 21st, 2011, 3:14 pm
Originally Posted by CBar
Hi,
The Bimota RAC43 have a differnt set of lower tubes and they are 29-25mm and not 30-25mm like the ducati.
I now have a sb8 axle and it is quite heavy and too short... it is 260mm long (like the 999 axle but the right side is not made to fit flush with the fork, so is in effect 10mm shorter)
anybody know how long the db7 axle is? Just mesuring the width of forks at the bottom would be enough...
Thanks,
Gray
Oct 21st, 2011, 3:49 pm
I was referring to the Ducati RAC 43 information that is in the 2nd link I posted.
Have you tried a 748-998 axle?
Chris
1996 SB6
Oct 22nd, 2011, 3:08 am
Yes the 748-998 axle is the same thickness as the 749-999 axle and 30-25 aswell... the difference is the 30mm shoulder on the 748-998 axle is longer.
Gray
