FS BIMOTA SB8 Marchesini Magnesium Wheels NIB - Ducati.ms - The Ultimate Ducati Forum
Old Feb 19th, 2011, 9:12 pm   #1 (permalink)
Please see my add in the Parts For Sale section of this website for complete details.
I have one new set of Racers Gold Marchesini Magnesium Wheels to fit the BIMOTA SB8 models .
These are real "RACERS GOLD" anodized and are not painted nor cold powder coated.
Last set of Racers Gold and last set of Marchesini wheels made for these BIMOTA models.
Please read my add for complete details
These are the same wheels the BIMOTA factory WSB SB8 used to win the WSB race at Philip Island in Australia as ridden by Anthony Gobert.
The famous Moto Corse SB8R also has the same wheels on it.
Contact Doug
(303) 761-4626
dougolmstedotr@hotmail.com
thanks
daotoys1 is offline   Reply With Quote
Old Feb 22nd, 2011, 10:36 am   #2 (permalink)
Contact Doug
(303) 761-4626
thanks
I have lowered the price. See the FS add for details
Old Feb 24th, 2011, 10:57 am   #3 (permalink)
I AM TAKING ANY REASONABLE OFFERS.........
Enjoy the ride
Old Feb 26th, 2011, 12:15 pm   #4 (permalink)
The wheels are now on USA EBAY auction.
You can search either Marchesini and/or BIMOTA to find them. Info and pics included.
thanks
Old Feb 26th, 2011, 2:51 pm   #5 (permalink)
Hi Doug, any chanc these would fit on the SB6R I have? Any idea if any mods would have to be done? hoping they are an exact swap, as U know the Anteras are heavy, and would U pm me a price or reserve? thanks Tim
flyin'duc is offline   Reply With Quote
Old Feb 26th, 2011, 3:28 pm   #6 (permalink)
They could be adapted to fit, but they would not just bolt right on.
I think that the rear axles sizes are different on the 2 bikes. this would simply need changes of the bearings, seals, collars and/or spacers. If you give me your rear axle diameter I can check this for you.
The front wheel; I think that the axles are different sizes . And if I remember correctly the SB6R speedo pick up is a mechanical one at the front axle.....I dont know this as a fact so just look as see. The speedo pick up for the SB8R/SB8RS is off the front sprocket.
Any wheel shop could adapt them for you. Ive had this type of thing done on a number of my bikes in the past.
For example; if your axles are smaller in diameter you can either have sleeves made to get the wheels to fit, or change the bearing, seals, and such.
If you can move a front speedo pick up to another location, that would be one way to adapt the front....or have the front wheel hub adapted to use your existing speedo pick up.
Look closely at your bike and get back to me.
If you email me I can send you close up pictures of the whhel hubs.
I think that the front and rear brake rotors on your bike will bolt on. You will need a 5 bolt Marchesini rear sprocket ( if you need one in 520 I have both a 39T and a 40T....and i can give that to you if you buy the wheels).
Anything like wheel adaptations can be done. It will take a little time and money to get them to work but not to bad.......it all depends on how mechanically inclined you are.....and a good wheel shop can help alot.
For example; I had a set of Marchesini mag wheels adapted to one of my bikes and it only cost me $200 USD at a local wheel repair shop to get it to work.
Since both the SB6R and SB8R/SB8RS use similar Antera wheels OEM/stock, it should be possible......easier than getting a wheel made for a different brand to fit ( and Ive done that too...).
Here is my email and phone #
Doug (303) 761-4626
thanks
Old Feb 26th, 2011, 8:22 pm   #7 (permalink)
Images: 6
fitting SB8S wheels to a 6R should be fairly painless. Wheels made for other brands(rear Wheel) are extremely hard to adapt due to the inboard rotor set up in the Bimota's. Cant go from 6R to 8 as easy because the wheel itself would need to be machined to fit the bearing for much bigger axle. Bushings are very easy.
JLSB8 is offline   Reply With Quote
Old Feb 27th, 2011, 1:08 pm   #8 (permalink)
Please email me;
Doug
BIMOTA SB8R/SB8RS Marchesini Racers Gold Magnesium 5 Spoke Wheel sets daotoys1 Parts and Accessories 4 Feb 26th, 2011 12:17 pm
FS: Marchesini magnesium wheels 748 916 996 998 tom.i Parts and Accessories 5 Feb 5th, 2011 2:46 pm
Marchesini Magnesium Wheels NYSport HyperMotard 16 Aug 2nd, 2010 12:44 pm
749/999 Marchesini Forged Magnesium wheels towerrtsk Superbikes 9 Nov 6th, 2008 12:55 am
