Dumb ST4S owner hooks up battery backwards - won't start now - Ducati.ms - The Ultimate Ducati Forum
» Site Navigation
Old Jul 28th, 2010, 8:09 pm   #1 (permalink)
Hello fellow Ducatisti,
Today i made the relatively simple job of installing a replacement battery much more complicated by hooking up the battery backwards. (2003 ST4S)
Initial symptoms:
- bit of a spark at the terminal on hookup (hmmm, that's different...)
- engine fan running with a cold engine (hmmmm, that's weird too...)
- no engine turnover on start (ok, whats up now...)
- red cable on (-) sign on battery (doh!)
Current symptoms:
- no starter action on thumbing the starter (yes, bike is in neutral with side stand down, doesn't work with side stand up either)
- satisfactory checks of start switch and kill switch
- engine will start and run if solenoid main contacts are shorted (with a now-somewhat-smaller wrench)
- no change in voltage on starter solenoid firing circuit when button is pushed
- 40a fuse for rectifier blown and replaced, no other blown fuses
- used multimeter to check for starter solenoid diode status on firing circuit. Showed open circuit one way and .5 v forward voltage drop the other way (I think this means the diode is still good.)
I know that in other similar situations guys have had blown starter solenoid diodes, but I can't find the diode and it seems from testing that, wherever it is, it's good. Does anyone know where this diode is for a 2003 model?
When i put the key in and turn to ON, the immobilizer light flashes once and goes out, and i get the light show and fuel pump noise. I think that this means that the immobilizer has accepted the key. Does the immobilizer affect the fuel and spark - would it keep the engine from running after bypassing the starter solenoid control?
Any suggestions would
be appreciated. Thanks very much for any help!
- Tom
Newport, RI
Tshugart3 is offline   Reply With Quote Quick reply to this message
Old Jul 28th, 2010, 9:17 pm   #2 (permalink)
I did the same thing, blew fuses but ran ok after replaced fuses. Better inspect all your wiring, with your nose (to smell melted insulation)
02 ST4S
04 FLSTC
07 DRZ400SM
Mojogoat is offline   Reply With Quote Quick reply to this message
Old Jul 28th, 2010, 9:24 pm   #3 (permalink)
ducatiboy's Avatar
Can't you short the battery doing that? What is the battery voltage now?
AKA "Doc"
LRRS/CCS EXPERT#X
Trackday Instructor/ VT Bike Night Founder/ Turn 1a Racing Team
"I'd rather ride a slow bike fast than a fast bike slow."
Ducati 748 Track Honda RC31 Race, CRF 110 Mini Motard, Kawasaki ZRX1200R Street
"If you want to go FASTER, take it to the track!"
www.Bostonmoto.com
ducatiboy is offline   Reply With Quote Quick reply to this message
Old Jul 28th, 2010, 9:26 pm   #4 (permalink)
Battery Voltage
Thanks - I'll take a look at the battery voltage tomorrow. What would it look like if shorted?
BTW, all other indications seems to show that the battery is ok - lights come on bright, fuel pump sounds good, etc. But when I hit the starter - nothing!
Thanks,
Tom
Old Jul 29th, 2010, 1:47 am   #5 (permalink)
And you didn't flip your kill switch off,on,off while fumbling around? Did you check all the other fuses?
danrduc is offline   Reply With Quote Quick reply to this message
Old Jul 29th, 2010, 6:02 am   #6 (permalink)
Yep - I checked all the fuses (I think). All I could find were the 40a rectifier fuse by the battery and the main multi-fuse block up by the clocks. Is there another somewhere that I might have missed?
Another question - does the immobilizer control fuel and ignition too? My fuel pump and spark plugs still work. Is it possible to bump start a bike with the immobilizer not working?
Old Jul 29th, 2010, 6:18 am   #7 (permalink)
Derek's Avatar
I'm pretty certain that the immobiliser also stops the sparks and fuel pump from functioning, or else a thief could just hot wire the bike and push start it.
The starter solenoid is activated by the ECU only if the right conditions are met; the bike is in neutral, or it is in gear and the clutch lever is pulled in. (It also cuts the ignition if a gear is engaged and the side stand is down)
So, if the safety interlocks are operating correctly and the ECU is not recognising this then it has an internal fault with the starter engagement circuit.
You can bypass the ECU from the starter circuit easily enough but you will also loose the safety features, some might think this is a good thing
If you confirm that the problem is with the ECU, you can wire the starter button to operate the solenoid directly by joining together the red/black and red wires to the ECU. (Body connector (grey) pins 1 and 28). This will though, disable the safety lockouts except possibly cutting the ignition with the stand down, and will allow the engine to crank, but not fire, when the immobiliser is enabled.
2010 MTS 1200 ABS
2003 ST4s ABS (now sold)
1994 907ie
Scotland
Derek is offline   Reply With Quote Quick reply to this message
Old Jul 29th, 2010, 6:51 am   #8 (permalink)
Update: battery voltages are normal. Also, connected the negative battery terminal to one terminal of the starter solenoid firing circuit, and then took the ignition key to ON. The bike started I'm immediately, even though I hadn't connected the firing circuit to the positive terminal battery terminal. Why would the bike start when the circuit gained a connection to ground with start button being pushed?
Also, can anyone tell me exactly where the immobilizer ecu is located?
Thanks!
Old Jul 29th, 2010, 7:42 am   #9 (permalink)
Moderator
RedST's Avatar
Images: 3
There should be a block of fuses and relays under the seat too.
Current pastimes:
2004 ST4s
RedST is offline   Reply With Quote Quick reply to this message
Old Jul 29th, 2010, 7:54 am   #10 (permalink)
Derek's Avatar
Thanks!
The ECU switches the solenoid by providing a ground to one side of energising coil, the other side of the coil is connected to +12V via red/white wire from fuse 4. By connecting the switched side to ground and turning on the ignition you completed the circuit and energised the solenoid.
That fuse also supplies the ECU and the immobiliser.
The immobiliser unit is under the LH side of the upper fairing, below the fuses. I don't think the immobiliser has anything to do with your problem.
2010 MTS 1200 ABS
1994 907ie
Scotland
Human Verification
Dumb question re: Battery Emerson Multistrada 6 Jul 22nd, 2010 10:42 am
2003 ST4s ECU in 2002 ST4s - No Start knj2002 Sport Touring 11 Oct 1st, 2009 6:54 am
Help! 1997 748s battery installed backwards! SuzukiSandy Superbikes 2 Aug 3rd, 2008 1:29 am
Dead Battery 2004 ST4s "is it a special or regular off of the shelf battery?" 2UpDuc Sport Touring 26 May 10th, 2008 2:10 pm
New GT owner about to ask his 1st allowed dumb question DMCTRUBY Sport Classic 14 Dec 12th, 2007 3:25 pm
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
