Battery help - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
Motorcycle.com
Old Jun 21st, 2006, 2:48 pm   #1 (permalink)
Battery help
Have I got a duff Battery ? I left it on an optimate for a week and it was showing a green light (ok). However it hardly turned the engine and then the selanoid was clicking. With the lights on the selanoid doesnt even click when trying to start. I put a voltmeter on the battery and it read 12.4v and then when trying to start (during selenoid clicking) it dropped to 4.8v. I also noticed the battery top was quite hot from all my starting efforts.
Is it ok to use a car battery with jump leads or will this cause some damage or blow a fuse. Ps- I think its the orginal battery.
Any comments greatly appreciated.
andpopst4 is offline   Reply With Quote
Old Jun 21st, 2006, 4:06 pm   #2 (permalink)
Oilhed's Avatar
Images: 7
Thats what happens when the cells are dry. They act like a capacitor - show voltage but drop immediately with a load. Is it a sealed battery?
Mark Flanagan
2005 Ducati ST3
Oilhed is offline   Reply With Quote
Old Jun 21st, 2006, 4:07 pm   #3 (permalink)
Age has a lot to do with battery strength. But I would check all the connections and make sure they're clean and tight at the battery, solenoid, starter, frame and negative terminal. It can be jumped from a car, just match the terminals. If it turns over quickly with jumpers, but barely turns over on it's own, it's probably time for a new battery. Check the connections first.
'05 ST3
'90 906 Paso
It's not just a Ducati, it's a disease!
jack is offline   Reply With Quote
Old Jun 21st, 2006, 5:04 pm   #4 (permalink)
Its not a sealed battery and the levels are between min and max. There is a bit of white furring at the bottom of some plates in some cells.
Battery Blues, and DUCATI Electrical Stick Hall of Wisdom 15 Nov 14th, 2009 7:01 pm
Bad battery, or bad voltage regulator? number9 Supersport 19 Jan 16th, 2009 10:10 am
Battery problems and fixes - HELP NEEDED RotoRooterGuy Ducati Motorcycle Chat 21 Mar 5th, 2007 7:55 am
Anyone here have a picture of their battery? 748sfromSD Superbikes 4 May 30th, 2006 9:02 am
Battery Safety ! Stick Hall of Wisdom 1 Apr 15th, 2006 11:13 pm
