Super trick/exotic and very remote starter button! - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old Mar 20th, 2017, 11:09 pm Thread Starter
Bryanc123's Avatar
Folks, what you see here is a highly trick/exotic and very remote starter button.
Directions: First, start off by disabling your starting circuit in your ecu by reversing all of your connections to the battery. Be sure to turn the ignition on for at least 10 seconds so you can make sure that part of the ecu is totally disabled and will never work again. Next, go down to the local Napa and pick up a solenoid push button starter and two ft long cables with connectors that will fit on the solenoid terminals. Once home, connect the cables at one end to the postive and negative terminals on your solenoid, then connect the other ends to the push button. Use zip ties to mount in the desired location and...walla! Be prepared to make your fellow riders green with envy.
What better way to increase the value of your St while showing the world you're super sharp and with the program!
SS904 and forsythem like this.
1026cc Fast by Ferracci 2003 ducati st4s
Bryanc123 is offline
post #2 of 11 (permalink) Old Mar 21st, 2017, 12:06 pm
It sounds like a good theft prevention device as well.
2002 ST2 (Yellow)
SwiftFF5 is offline
post #3 of 11 (permalink) Old Mar 21st, 2017, 1:26 pm Thread Starter
Bryanc123's Avatar
Who needs a fully functioning ecu or immobilizer system when you got this?!
post #4 of 11 (permalink) Old Mar 21st, 2017, 1:52 pm
Moderator in moderation
mlukason's Avatar
You know...the starter on these bikes eventually slows down too. Plenty of time to figure out how to retrofit a kick starter!
Stick likes this.
Mike
2006 ST3 - 2004 KLR 650 (the Truck)
NEDOC
mlukason is offline
post #5 of 11 (permalink) Old Mar 21st, 2017, 3:58 pm Thread Starter
Bryanc123's Avatar
Yeah, or maybe I'll find a way to fry that as well ? A kick starter would not only make it more unique, but would also be a good way to limit my use of the bike too!
post #6 of 11 (permalink) Old Mar 21st, 2017, 6:45 pm
SS904's Avatar
Innovative!
Kick start... I started to look at old Triumphs on eBay after watching American Picker the other night. They had dug a '67 Bonneville out of pick that looked like it was ready to ride. They got it for what I figured was a steel, and according to what I saw on eBay, it was! It occurred to me that I probably don't have the knees anymore for a kick start twin, so I'm safe for now!
Dan.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is offline
post #7 of 11 (permalink) Old Mar 21st, 2017, 7:24 pm Thread Starter
Bryanc123's Avatar
Originally Posted by SS904 View Post
Innovative!
Even if you had the leg to work against all that compression on the Duc, the first time it kicked back it would probably send you into orbit!
post #8 of 11 (permalink) Old Mar 21st, 2017, 7:29 pm
SS904's Avatar
No kidding. Especially with your high comp 1026!
Dan.
SS904 is offline
post #9 of 11 (permalink) Old Mar 28th, 2017, 9:22 pm Thread Starter
Bryanc123's Avatar
In all seriousness, I'm starting to think this might not be such a bad way to go. Does this completely circumvent the immobilizer system that's been known to have problems and leave people stranded? Is a coded key needed to start the bike now? Before all this happened, I had quite a few times where the starter wouldn't crank the first time I turned the ignition on. Usually, after I turned the ignition off and back on again it would then be fine. I'm wondering if these were early signs of things going bad with the ecu's ability to recognize the key. However, the owners manual does mention that the bike may not recognize the key on the first try, makes me think that even Ducati realizes it's system isn't without it's flaws.
Maybe it's just my imagination, but it also seems as though the bike's battery has a little bit more juice for cranking the starter with a more direct setup like the one I have now.
post #10 of 11 (permalink) Old Mar 29th, 2017, 1:51 pm
Official Sponsor
A mod like that actually ratchets a big bunch of value off your bike if you ever want to sell it.
I can't imagine what kind of buyer would say "oh, yea!, a modified ECU and homemade starting circuit".
I'm glad it's working for you but rider instituted electrical mods are generally just not appreciated in the used bike space.
M./
Innovative Electrical Upgrades Since 2002 |*EVERY* motorcycle will start in 1 second or less if the starting circuit is properly engineered. Install our HICAP II starting circuit upgrade to the get quick easy starting you expected from your high-performance engine. Excess cranking accelerates wear on the; battery, starter motor, sprag clutch and intermediate gear. - - Pay a little now or pay a lot more later. Click to learn more Motolectric.com |
motolectric is offline
Human Verification
